Originally Posted by
AmeriStar
Fuel temperatures of 130 f to 150 f for diesel is quite common to see on hot days. Althought the flash point of diesel is within this range, don't worry, the autoignition temperature is above 400 f.
Hot temps do have an affect on the 'amount of fuel' you purchase at the pump. Try to purchase your fuel early in the day when traveling thru hot areas. Diesel fuel expands and contracts depending on temperature.
At the 60 degree, 231-cubic-inch, standard a gallon of diesel fuel contains a specific amount of energy (approx 145,000 btu). At 90 degrees, however, the same amount of diesel fuel expands to more than 235 cubic inches; but pumps are still set to deliver the standard 231 cubic inches.
Every degree, over and above the 60 degree standard, diminishes the energy contained in a 231-cubic-inch gallon.
