CC Owners,
The System Check on my coach is doing funny things - well not so funny things. I had been stationary for two months before moving last week. The System Check came on unexpectedly when I hit a bump in the road. I actually first noticed the dash lights flicker then the System Check came on. It did this repeatedly every time there was a slight change in direction or bouncing over a bump in the road. Finally, the repeated on-off cycles, sometimes completing a check and sometimes not, set off the propane monitor. I had to pull over and manually reset the propane monitor.
I don't have a clue what is going on. I'm thinking either an intermittent ground or a problem with the power supply to the System Check board. Any and all advice is welcomed. It would also be good to know where to start looking for the grounding as well as the power supply. I did not have this problem when I parked it, although the System Check did come on a couple of times when the waste water tanks were nearing full, or the fresh water tank was nearly empty. The coach is a 1990 chassis and a 1991 conversion sale date.
Thanks to all of you that may be able to point me in the correct direction.
