Results 1 to 10 of 38
Thread: Air Force 1 Towed Braking system
    Aug 2008
    Walla Walla, WA.
    504
    Question Air Force 1 Towed Braking system
    Hope I can use a 'brand' name here without fear of my post being blocked.
    I was looking for a few reviews on the Air Force One Aux. braking sys. now that some here have had it in use for some time.
    Pro/Con, would you install the sys. again?
    Thanks for the input.
    Nichols Hills
    2,465
    I have had several braking systems and this one is the best. I am in the process of reinstalling it in the 2007. One important thing to note is where you install it on the coach. They have redesigned the tank / valve assembly, which is a substantial improvement over the initial design, so I would recommend it without reservation.
    As JDUB has mentioned, they have redesigned the tank/valve assembly which is a vital improvement. It is also just as important to find a suitable and secure spot to mount this assembly under the bus.
    We have had ours for just about 3 years now and we are very happy with the performance of this product.
    No problems with recommending the Air Force One....
    May 2006
    LaBelle
    474
    Larry,
    On my former 99 CC, 98 Chassis, I had the unit mounted on the cross member where the air dryer is located. It fell off twice prior to this but after mounting on the cross member it stayed. Local dealer could not figure this out on their own and I had to tell them where to mount it. They came to my home since I did not feel safe in driving the bus with the tank hanging down. Unit is excellent after the initial bugs were worked out.
    Sep 2009
    Nowhere
    288
    Got mine last summer installed direct by them in toad and bus. First class people to deal with and the unit works as advertised. Easy to hook up and unhook from the toad. My tank/valve is located in the engine compartment and is a very neat and clean install. I would get it again!
    Feb 2009
    Austin, TX
    963
    One more confirmation of the product. My tank / valve is located inside the curbside engine door, just outboard of the Bus air compressor.
    Question
    Wondering, what makes Air Force 1 brake system better than others.
    Many say it is, but give no reasons.
    Feb 2009
    Austin, TX
    963
    For our Lexus, it was the only system that would work. That aside, it provides proportional braking with minimal hookup and essentially invisible systems in the tow.
    Apr 2010
    563
    I agree that the Air Force One system is so easy to hook and unhook, No fooling around with the seat and brake pedal all out of site and works as advertised!
    Jul 2011
    Smithsburg, Maryland
    146
    I have a '92 CC. Your pics are a great help. Can you give me a hint where on the chassis to look for the point where I splice-in the air line?
