Increasing the amount of positive caster will increase steering effort and straight line tracking, as well as improve high speed stability and cornering effectiveness. Positive caster also increases tire lean when cornering (almost like having more negative camber) as the steering angle is increased. With power steering, you won't notice the increase in steering effort caused by positive caster as it increases in a turn. The effects of positive caster are pretty much "positive," especially increasing the lean of the tire when the vehicle is cornering while returning it to a more upright position when driving straight ahead.
On vehicles set up to drive on the "right" side of the road, the curb side is aligned with a little more negative camber (usually about 1/4-degree) and a little more positive caster (again, about 1/4-degree) to help the vehicle resist the influence of crowned roads that would cause it to drift to the right. Since most roads are crowned, cross-camber and cross-caster are helpful the majority of the time, however they will cause a vehicle to drift to the left on a perfectly flat road or a road that is crowned to the left.
- You may not post replies
- You may not edit your posts
Forum Rules
