Yeah, but was it true? I don't think there is anyone else on this forum that has posted pictures of food.
Ok, I would normally show more compassion for a fellow POGer but since every one else is being S....ity (Pun intended), I'll chime in to. I think I have two solutions to JDUB's sanitation engineering dilemma.
After reviewing previous post as to the volume of the matter at hand and determining that, (at the suggestion of unnamed sources) this equals the by product of a small community, I contacted my city Sanitation Engineer for advice and we came up with two solutions.
1. Buy a stacker trailer, put the Hummer in it and put 2 Port-A-Johns on the lift, raise it then install 2 more Port-A-Johns in the front ahead of the Hummer.
2. If number 1 is not acceptable due to no highway shoulder to pull over on or getting out in incliment weather then my next option would be to remove the existing bathroom, remove the passenger windscreen ( as they say in Britain) remove the passenger seat and bring a Port-A-John in through the hole and install where the bathroom use to be.
This would allow for use during inclement weather or when there is no shoulder to safely pull of the road on. During travel," Mrs. JDUB" could switch driving positions with JDUB on the "FLY" and he would not have to pull over or even slow down.
The Port-A-John could be vented out the roof using the existing exhaust fan or should it be replaced with one of those 42" attic fans you see in older homes!!!!!!!!!
And for cosmetic purposes, You could Super Glue a matching lamenant material to the sides of the enclosure to blend in with the current decor or wall paper it.
Oh and what is best about either of these solutions is there are no moving parts, no air needed, no electricity needed, no water needed and lastly no plumbing to stop up. (A direct port to the end result. I haven't solved the process of getting rid of a full Port-A-John in a motor home, but I am working on it. Good Luck. You have some really harsh (friends are they)
Don't worry about the safety issue of him going to the bathroom while driving, "HE WILL BE SEATED"
This may be an easier solution, at least for getting the Port-A-John emptied.
Get a motorcycle lift installed on the rear bumper of the bus.
Place the Port-A-John on a platform on the motorcycle lift.
Put a door in the rear closet to gain access to the Port-A-John.
This solves several issues.
No changes to current bathroom so other family members can use a "normal" system.
All the Aroma is kept outdoors.
Minimum modification needed for installation.
Easy pump out, just lower the motorcycle lift platform, and Billy Bob Pump out truck has easy access.
When parked, lower the platform and Jdub has easy access without even having to enter the coach.
And just think of the "friends" he could make at campgrounds when people ask him to explain this one of a kind modification!
On a more serious note:.
Can you tell if the macerator is running when you flush? If not, there has got to be a fuse somewhere that may have blown, if the macerator was overworked/overheated.
I have 2 macerators on my bus, and if they are not used on a regular basis they tend to lock up and I have to manually turn the shaft at the end to get them going again.
And there are a lot of things that can clog up a macerator. You may want to go over the "toilet rules" with the rest of the family.
[QUOTE=Jerry Winchester;73577]Okay after years of having an air flushing anaconda processor, the new bus has some manner of macerator / toilet combo that has stopped flushing. I push the button, some water runs in, it makes some kind of noise then nothing.
Originally it would add water, flush, the macerator would log chop then it would add some more water and wait for the next deuce.
Just install beneath the flapper....
Gordon, I like your solution but you must take into account that if (and I don't know) a well endowed man was to get caught in the flapper, that would not be as severe and accident as getting caught in your solution!! This theory could be a
"long shot but could happen".
Andre, You do have the easier solution but you failed to take into account how little of JDUB's money you would be spending and everyone knows how POGGERS love to spend someones money.
The new techno taco grinder lives again. The next high point in my life will be the day one of you rivet herders calls for the Indian trick that makes this bad boy come back on line while your wife is trying to poke an Anaconca down it with a coat hanger.
Just call 1-800-BITE-MEE. And if you ask real nice I'll give you a new taco soup recipe.
Hi Jdub. What was the final solution? sorry about the pun.
I am sorry to say that this is very hard to read without laughing considering the parties involved !!!!
