I've just spend a week in Oregon where it's been very rainy. I've noticed some water leaking into the bus... mainly by the drivers side window and above the front door (and a little in the middle between the two windshields). Also, I little on the side of the bus between the second and third side window (not around the window itself, but about .5" below it).
I talked to Troy of Liberty and he said it's most likely the marker lights near the roofline and that I should use caulking to seal up the screw holes and other areas and that it should be done once I year (nice that they didn't tell me that when I bought it). He didn't think it was from the entry light that's over the door (even though I mentioned that the gasket was falling apart)... I think he thought that was sealed from behind.
The problem is that it's been raining here everyday for at least half the day so there hasn't been time to inspect, seal and let the stuff dry.
It looks like I'm going to be able to park in a warehouse for 24 hours tomorrow, which should allow me time to seal it up and let it dry before coming out into the rain again. I just thought I'd ask you guys to see if you've run into this and if there is anything special to look for or other areas to think about sealing up.
Also, I've been told that there is supposed to be a drain that allows water to drain from the tracks of the drivers side window. Does anyone know where it is and how I could clear it out, since it doesn't seem to be working.
This sounds like a maintance item that should be thought of before anyone heads into the rainy Pacific Northwest.
