From my limited viewing position at Bella Terra, the XLII across from me had some manner of light bar out on the extended end of the awning. Does anyone know what that is, how it works and how to get one?
Thanks,
Jerry
Thanks,
Jerry
Millinnium has them,but I am not sure if they can be retrofitted.
Aw c'mon Jack....
You can retrofit anything if you're willing to write the check.
Just start your conversation with "I don't care what it costs......."
Jerry, the coach across from you was a Legendary. Since you can't go there, Parliament did the same thing with there awnings so just give Ben or Rick a call and see how entailed it might be.
2005 Parliament XL-II SS
2007 Avalanche
Hey Jerry, you could just hang some purple and gold Chinese lamps from the Girard. Just say the word and I'll order some for you!
Tuga & Karen Gaidry
2012 Honda Pilot
hey Paul,It is just like the Ferrari dealer told a friend of mine,we can fix anything no matter what it cost.
Jerry, I saw the same thing for the first time while at Millennium last week. There were 2 newer buses, one being the 2012 HS45 owned by Mr. Jones. I think the other was a 2011 HS45. Both had there awnings pulled in so they must be able to turn on, probably in or out and were color white. It sure gets your attention and I liked it on the awnings. Should really look good with the awnings extended.
AL
I sense a bling contest. Either that or someone is trying to keep up with the aforementioned Jones'.
Jerry,
Probably the easiest way to get one is to just sell the new Marathon and step up to a Millennium. Millennium also has a LED stip that runs the full outside edge of the awnings that provides nice light.
