Headed there now, thanks
Robert, I will let the experts address the DDEC issues. When you look at your underside. compare the length of the driveshaft between the U joints on your 8V92 and a Series 60 40 footer. Also see if the tag axle has been modified. I think it is very important to maintain the geometry Prevost built into the 40 footer with Series 60 to avoid vibrations and the damage than can ensue.
As to the mileage, why don't you run some numbers. For example, let's say you drive 15,000 miles. My 8V92 was geared so top speed was 69 MPH, 72 downhill. I drove it at around 60 MPH and I got 5.6 MPG. My Series 60 coach is 5000 pounds heavier, and I drive it 62 MPH and originally got around 8 MPG, but since the change in fuel to the low sulfur I more consistently get 7.5 MPG. These are not guesstimates, but actual numbers since I record every gallon of fuel ever put into the coaches. How you drive will have a substantial impact on your fuel economy.
So lets pretend fuel costs $5.00, which is much higher than it is today. On my 8V92 my fuel cost would have been $13,393. On my Series 60 my fuel cost $10,000 for a savings of $3,393. Now that is not chump change, but if you drive less than the 15,000 miles the savings, even at $5 per gallon is not so significant. Only you can decide if the cost and effort to swap engines and transmissions will be justified based on fuel savings. In today's dollars the savings, even at 15,000 miles per year is down to $2375.
If you are right about fuel going out of sight, maybe you can justify it, but your biggest expense even with a coach of your vintage is still going to be depreciation. Personally, we loved our 87 Liberty and had no intent to replace it, but when it was damaged by a fire and we faced 9 months without it, we bought our current 97 45 footer and will never go back to a 40 footer. The changes Liberty made in the 10 model years was significant and despite how much we liked our 87, it just could not compare.
I second the notion that you may not see the increase in mileage you are looking for. My S60 usually gets around 5.50 to 5.75 mpg. I have only seen it better if I drive much slower than I the speed limit. If you have a working 8v92, I would think you would be hard pressed to ever recover any of the costs involved in a swap just in fuel. FYI, my 45' weighs in at just under 51000 lbs. and I flat pull a 2010 Tahoe.
Hi Mark,
As I'm sure you're aware, the emissions controls on the later S-60's do have a cost in terms of fuel mileage; nonetheless, Robert made it very clear in his earlier posts that he's a talented fabricator with a complete fabrication shop at his disposal and that he likes his bus and wants to keep it. This is great project and will provide a wealth of information and expertise to the forum. I'm looking forward to lots of pics. Robert, good luck!
Thanks to all for the great input. I am definately looking at this project with eyes wide open. Having the S60 for 0 $$ is a plus but if I have to swap trannies to a world the cost could be prohibitive. After reading several threads from the Diesel Talk forum it sounds like the world trans is needed. I did some measuring today and the clearance is not an issue. The length of the S60 to the trans looks like it needs about 3 to 4 more inches, like Jon said earlier.
As a plus though the engine rotations are the same.
Another issue I noticed today was the intercooler needed for the S60. More to think about.
I am going to raise it up tomorrow and look at the drive shaft, tag and trans mounts.
This may have some real information you need. Scroll down to "HardHeadKens" post.
http://www.busconversions.com/bbs/in...topic=12909.15
Thanks Andre,
That was quite a discussion and alot of info. We use to subscribe to Bus Conversions when we converted our first Eagle. I thought they went out of business. Sounds like my tag axle is going to prevent the B500 trans from fitting. Guess I will scrub the idea for now until I can figure something out.
Jon, thanks for the welcome, I am very happy with the content of this site. I look forward to enjoying the discussions.
I forgot to mention my Series 60 is DDEC III. Mileage figures you should rely on are for those who have DDEC !V. Later versions had different mileage. It may in fact turn out the improvement in mileage may not be so great, but with the Series 60 there is one distinct advantage. While a guy is waiting for the 8V92 turbo to spool up the Series 60 with its low end torque will get the bus and that stacker off the line and moving.
And welcome to POG. I hope you know by now we will always answer your questions, and on certain rare occasions we may actually offer the correct answer. If you don't take any of us too seriously, and don't mind hanging out in this asylum we call POG you will fit right in.
Mark, after re-reading my post this morning I see that I may have come across a bit strong, sorry.
Over on the Wanderlodge forum, WOG, we have members contemplating swapping their two-strokers for S-60's. We have one thread happening now where a 6V92 is being swapped for a Cummins 8.3.
