Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Rivet Gun Needed
  1. #21
    Jeff Bayley Guest
    Default Ordered the stuff
    Harry-
    I ordered the parts you recommended including the extension and the rivets. Thank you.
  2. #22
    Alexandria
    2,161
    Big Harry & Dale,
    The bottom panel, along the rivet lines, had some sort of adhesive to the superstructure. When attaching the new ss panel, what element should I use, if any? Would just regular silicone serve the purpose - I want to make sure I'm doing this right, because I'm only doing it once.
    Thanks
    Mike
  3. #23
    dalej Guest
    Mike, Black silicone will work, it seals out the dust and moisture, your doing great. I seen the word NEW, you naughty naughty boy!
  4. #24
    Mike,
    I saw where you suggested you have to beat the bay door structure back to shape. It may cost a few lewbucks, but if you have a metal working shop nearby (such as a company that does AC ductwork or a custom metal fab shop) they will have a press brake or regular press.
    With a few blocks to support the ends or a flat forming block they can exert the tonnage you need to straighten out the Buffet bent panel. What may take you a lot of time to do will take only minutes.
    But I tend to avoid relying on others, it is probable you already have the tools. If you can rest the panel on blocks and sit a jack on the panel directly under a bus support point you have several tons of power at your disposal. The key to repairing it is where is it bent, and can you put the straightening force in the right place?
  5. #25
    Alexandria
    2,161
    I bought a large workbench vice and manhandled that to do some straightening, along with a mini sledge and bad language.
    Plan B was to go to a body shop, however I wanted to try it myself first, screw it up and end up by paying even more when I show up hat in hand.
    BUT... You're idea about the 22 ton bus press is a great idea and I'll keep it in mind for the future.
    Your comment in another thread about this group amassing a great deal of info in a short period of time is right on the money - we can conquer the world
    Mike
  6. #26
    win42 Guest
    Mango: I'm not aware of what Jon is refering to, but what he is saying makes sense if indeed you have a bent door panel. You always have to get the base structure back in place before adding the outer trim panel. Dale is correct on the silicone, but a very thin coat, so it won't bulge the panel out. clamp it tight before riveting if you can. I'm sending you a private message, check it out.
  7. #27
    Ben Guest
    Mango,
    I've found the perfect book for you
    It can be purchased for only $9.95 here:
    http://rvbookstore.com/shop/detail.aspx?p=883&m=2
    That's a lot cheaper than a new rub rail, so go buy it before the next Jimmy Buffet concert rolls around
  8. #28
    Alexandria
    2,161
    Ben,
    Can I get that in a Braille Edition?
    MM
  9. #29
    Ben Guest
    Mango,
    I didn't know your eyes were THAT bad. No wonder you scrape up the sides of your bus... maybe what you really need are bifocal rear view mirrors and some 6' curb feelers.
    Or is it that you just like the tactile sensation of scraping your fingers (or bus) across rough surfaces?
  10. #30
    Note to Ben:
    When you break someone's gonads about dents and dings, it would be prudent to avoid dinging your coach at all costs. Guys like JW lurk in the background waiting for the smallest mis-step so he can light that flame thrower.
  1. Hub Cap needed
    By jkbriggs in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 03-04-2009, 03:57 PM
  2. Missing Rivet
    Last Post: 04-10-2008, 11:37 AM
  3. Mirrors Needed
    By jimshoen in forum Busted Knuckles and Greasy Jeans
    Last Post: 11-15-2007, 07:58 PM
  4. Aux Gen and GPS needed
    By Jeff Bayley in forum Sparky's Corner
    Last Post: 11-11-2007, 12:57 PM
  5. Wireless Help Needed
    By CAPT MOGUL & Sandy in forum POG Forum for the Computer Challenged
    Last Post: 09-20-2007, 02:57 PM
