Results 1 to 10 of 11
Thread: Drilling holes in carpet
Hybrid View
    dreadnought Guest
    Default Drilling holes in carpet
    The walls and floor of the bays in my bus are covered with carpet. I want to mount a fire extinguisher on the wall but when I tried to drill a pilot hole the bit grabbed the carpet and started to unravel it. Anybody know how to do this w/o ruining the carpet?
    Heat up a tool such as a screw driver tip until it is very hot and melt the carpeting in an area slightly larger than the hole to be drilled, and if possible open a hole in it.
    It is kind of like melting the end of a nylon rope to keep it from fraying.
    If you have a carpet with real wool or similar materials that do not melt then you have to make a cut with an exacto knife or similar tool so the end strands do not catch on and wrap around the drill bit.
    Alexandria
    2,161
    Jon's got more helpful hints than Heloise.
    Would this be overkill?
    MM
    win42 Guest
    I would try a large center punch hit with a hammer. It should spread the carpet away enough to get the screw past it. Then when that doesn't work do what Jon says his way always works.
    Nichols Hills
    2,465
    I actually used one of those el-cheapo soldering irons you get at Radio Shack and punched the holes in the carpet with it. If you clean it real good, you can even use it to solder again.
    That's an even better idea than heating up a screwdriver with a blow torch.
    You really want to make sure the hole is open and away from the drill because once the drill bit hooks onto a stray strand of carpet it seems like it unwinds faster than Jerry can say Ohio State U.
    dreadnought Guest
    Lessee here, screwdrivers, soldering irons, blowtorches,
    knives, center punches, hammers, monkees, pimps, and ... I get the picture. Thanks guys, a bunch of heads is better than my mine.
  1. OKC Drilling Rig Tour
    By Jerry Winchester in forum RALLIES AND GET-TOGETHERS
    Last Post: 09-24-2009, 03:28 PM
  2. CARPET CLEANING
    By JIM CHALOUPKA in forum NEW MEMBER INTRODUCTION
    Last Post: 09-09-2009, 12:47 PM
  3. Out With The Carpet
    By Joe Cannarozzi in forum Busted Knuckles and Greasy Jeans
    Last Post: 09-01-2008, 11:18 PM
  4. Outdoor Carpet
    By grantracy in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 03-26-2008, 08:54 PM
  5. Jerry's Carpet
    By ken&ellen in forum Ah, Nice Coach...
    Last Post: 04-15-2006, 11:05 AM
