First of all, Hi again to all my friends (and extended family) at POG!
I'm finally back on the road. After nearly six months working on behalf of BP in response to the Deepwater Horizon oil spill incident in the Gulf of Mexico, the program for Emergency Advance Payments transitioned to another process which gave me an opportunity to take my leave and get back to retirement.
So.... as I fired up the bus to head for home I was presented with a couple of problems: the ABS brake warning light is on and I had no turn signals or hazard flashers. No left..... No right...... nuttin'!
Tried cycling the turn signal breakers and completed a futile search for the turn signal flasher. No luck. The turn signal flasher appears to be the most likely culprit since, according to Prevost, it's the only common component regarding both the right and left turn signals.
Hence, I have an appointment for first thing tomorrow to address these issues at Prevost in Jacksonville. Since I'm here, I'm also going to have the engine belt tightening air bags replaced, since I have no way to perform this repair at home and, being 11 years old now, they are ripe for replacement.
I'll post the outcome and any observations afterward.
It sure does feel good to be back !!!
