Leveling switch question
After 5 months of getting the coach set up to handle my chair Im finally able to LEARN the prevost. Here is my first challenge. The leveling system up/down button is acting up. Acting up meaning if say I put the selector in the right rear position and then hit down I normally just hear a little pssst and thats it. Ive found if I rotate the selector to the opposite side which again i only get a short pssst of air below and if i keep rocking the up down switch enough times getting these little short air exhausts and move the selector enough times from left to right to front to left to right to front, eventually for some unknown reason the air will start to exhaust. From that point on it acts properly in any of the three positions. I can level the coach and it holds its level well.
My question is would it be the up/down switch or the selector giving problems. Since when it starts working all positions work its not in the norgrens. Doesnt seem to matter which of the selector positions its in when it finally starts working. At first i just had to move the selector a few times and rock the up/down switch multiple times to get it working. The last time it took about 10 minutes of playing around like this and then sure enough it exhausted once and worked fine to level all three points on the coach. Is the up/down rocker switch the first thing to test and if so how does one go about doing that?
Thanks for any experience you guys can share.
Craig Lenz
Yellow Grass, Saskatchewan
1996 Angola XLV #5688
