Originally Posted by
Jon Wehrenberg
I doubt if Woody's bus has forward shutters but it is easy enough to verify.
What is needed is more information, such as where is the noise coming from, does it happen on OTR or just heat, is it affected by adjusting the thermostats for forward or whole bus temperature?
Neither of my OTRs in the 87 or the current 97 made a noise beyond the fan noise. I cannot imagine a valve opening and closing making that noise. Is the outside air supply baffle located in the OTR bay on the driver's side loose and banging around? On both my coaches the outside air supply was blocked so the system was always recirculating.
