Bus can't be moved on it's own...
Hi All,
My Cousin is here from Ca. to make the trip to Fl. with me this year...and the last time I pulled the bus into my driveway I had gotten stuck in the sand again because of the small knoll up into my property from the street...
I had Good Sam Road Service come from Jackson, NJ..."All Shore Towing Service" 732-928-5597...
Brian the driver lifted the bus up with his wrecker and simply moved it over about one foot to get it out of the sand it was stuck in...then he pulled it up about 3 more feet into my property and off the road altogether...
That is where it's been sitting until John got here and I thought we would be able to just leave for Fl...but now when I try to bring up the air the beeper which tells me the bags aren't yet filled with air...won't stop at all...
John thinks it's not a problem with the bag but the Leveling Control that allows the air to fill the bag...
Prevost in Springfield, NJ wants me to have it flat bed towed to them from my house in Bricktown, NJ if they're to do anything...they would want it so they could pull it over their pit or raise it up on their lift in the shop...so they could determine the exact problem...
MY Question is does anyone know of any one closer that I could maybe call that would have the equipment like All Shore Towing Service does that got the bus up into the yard and out of the sand for me a month ago when I'd been stuck in the sand on the enge of my driveway ...the driveway is paved with blacktop macadam...it's just the knoll that causes all the problems...
All Shore Towing Service could maybe fix ti but said they're too busy to come and look at it...and have no room to have it towed there..."I guess they don't want to do it:"...
This is the only problem I've had with the bus besides the Kubota Generator that so far no one can fix either...It just won't run at all anymore...and I sure miss that...
Any suggestions greatly appreciated...Please...We can't go to Fl. if I don't get at least the air fixed...
Hugs Always Viv...
732-458-3480 in case that's easier for someone...
Viv,
You may not like what I am to say but you need to learn more about your coach before you attempt to drive it.
There is no beeper to tell you the air bags are not up. You should have an audible alarm on the brake systems. Each should have a red light if pressures are too low accompanied by a buzzer. There should be a gauge for each circuit. If the red lights are out and the air pressure gauges show pressure at around 125 PSI the bus is aired up.
The only other beeper would be for your tag axle. It has to be down before the beeper goes off.
If your bus is not coming up to ride height your level low system may be set wrong or your ride height solenoid valve may have a bad coil, a 3 minute fix. If the level low system is set in the manual mode there should be a red light on the dash to indicate that, but no alarm of beeper.
But before anyone ever drives a bus such as we all have they should know and understand the brake and air system well enough to at least understand what the gauges and beepers are telling them, and should understand the working and function of the level low system. Sorry for the harsh response, but I fear for your safety and the safety of others.
Viv, the very loud beep-beep-beep alarm is probably the warning that the tag axle is up (you should also have a dash light on that says "Tag Axle". The warning means either that the lift lever is in the up position or that the bus can't build enough air fill the aux tank for the suspension to push the tag back down. The later condition would also keep your suspension bags from filling to lift the bus to drive height. If only the beeper is on but not the warning buzzers and lights for low air in the brake tanks, and if your air gauges read 100 or more, you may just need to flip your tag lever to the up and then back to the down postion while the engine is running on high idle. If that doesn't fix it then you probably need a pro. It sounds like you have road service through Good Sam. If so, you should call them.
The beep could also be the low air warning. The air compressor might not fill the primary and secondary air tankd past 60 PSI to then alow the air to start filling the air bags.
Bottom line, Jon is correct, you need to learn more about the basic operation of the bus.
Viv. Try Yellow pages in your area for Truck or Bus maintenace and repair.
Viv,
Does the coach build any air pressure at all? It might be the air governor. Can you get access to an external compressor to air up your coach and see if the coach air compressor will hold and maintain 125#? If there are any leaks with the bags or leveling valves you should then be able to hear air escaping without the engine running. If it won't build & hold air, the compressor or governor would be where I would look.
Hi Gary,Lise, and all who responded to "Bus Can't Be Moved On It's Own.
I called Good Sam, and got a manager there..Explained the problem to him and my own inexperience..He sent me a Mechanic...and nothing was as I'd been told it was, "prior by Good Sam's "All Shore Towing Service 732-928-5597 Driver Brian:" ..Now the Mechanics sent by Good Sam "SRS Auto Plex.732-681-5667 Jack and Chuck" have been here for two days...and still have to come back with two parts to finish up..
I'm still not able to properly describe their findings they found the only reason the bags wouldn't take on air was a control switch that hadn't been turned on after they had dumped the air bags..I think..WE're not finished with my getting all this down on paper that I can relate to..
Jack, got the air to go in the bags in minutes..and the bus rose to better height than it had ever before..
Then he opened the Kuborta Generator Bay and STAT jump started the Generator..saying he discovered a part that allows shutting the genset off was missing..Said he ordered it and we're still waiting for that to arrive..but the Generator works fine..I stood there with tears in my eyes at finding out how I've been cheated again by workers who steal or are incompetent...and so grateful at hopefully finding a Mechanic who is honest...but even him I'm afraid to really trust until I see how his work holds up..Burned as many times as I've been one doesn't recover instantly, no matter what happens..Hugs Always Viv...
About now I'm skeptical of what any mechanic tells me..but again I have no choice but to trust, and wait and see.. Down the Road if he is competent, I expect he made extra money on me but that will happen no matter what help I get..Par for the course for any non-mechanic woman..
I wanted to add more but the program jumped around and wouldn't let me...
Jack the new Mechanic who owns SRS in Avon, NJ did much more than get the Bags to Fill and find the Kubota Problem...
He adjusted the brakes easing up that very hard to depress pedal.. since day one..!! now they're easy..!!
He remoced the Auto Take Up Reel for the Power Cord from my Dolphin and re-installed it in the bus...I now can run on 30 amps. just can't use the double burner elec. stove that I didn't want anyways...Also changed the 50 Amp out let I'd had installed on my house and now it's 30 amps again..I bought a new one burner 20 amp. Stove .I may find a two burner down the road...and I can only use one AC at a time which is all I've ever needed...If in the Salon I only need it there and if in the Bedroom I only need it there..small fans always helped circulate the cool air enough for me in gas engine RV's..I prefer no AC if the temp is bearable..
I learn more about my coach every day..and I never exceed the speed limit...usually drive under it..
No longer having to push up to 80 MPH to get the French Canadian's from the Port of Auth. NYC. to the Casino's in Atlantic City so they can have their full 6 hours there to gamble..Now I can Cruise and enjoy the ride for the very first time in a real bus..I'm in no hurry to get anywhere..
AND the least little thing that I see change in my instrument panel I will be pulling over to check out STAT...just as I always have in any RV..IF I'm anything I'm too cautious...!!!! and I don't think any one can be that...I LOVE MY BUS...See Dec. Issue BCM and give me a hug instead of picking on me Jon...
Hugs Always Viv...
Journey One's Cruiser
88 Prevost Le Mirage XL
Viv, If you can, have Jack check the fluid levels, bleed the air tanks, and check your tire pressure before you hit the road. Good luck, and most of all safe travels!
Viv,
Not picking on you but trying to get you to understand your bus. Please go back and re-read my 4th paragraph in post #2 above.
It is clear you had other issues which the mechanics appear to have solved, but the only one you posted was regarding ride height and all you had to do was know how to position the leveling system switch to inflate the air bags.
I am concerned for you and hope you will get a better understanding of your bus for your own safety.
- You may not post replies
- You may not edit your posts
Forum Rules
