Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Lost Direct TV signal
    May 2010
    Nevada, MO
    32
    Default Lost Direct TV signal
    On our last trip the in motion satellite worked fine through half the trip. The next time I turned it on --no signal from Direct TV. I've hit the red button to reset, unplugged for 15 seconds, reset all of the settings and still no signal. I can hear the satellite dish trying to acquire but nothing happens. I miss my old hand crank dish that I could "eyeball" in in about 30 seconds. Any idea's ? jjf ( The receiver works fine--brought it home, plugged it in and had instant signal)
    Nov 2006
    thomasville,nc
    1,209
    I had an LNB fail this year,your problem sounds the same.
    Aug 2006
    Houma, LA
    1,783
    John,
    It sounds like your problem is in the antenna. Who is your antenna manufacturer?
    If it is TracStar just give them a call and they can walk you thru a "reset". I have done that and it is easy.
    Good luck!
    Tuga & Karen Gaidry
    2012 Honda Pilot
    May 2010
    Nevada, MO
    32
    I have a Winegard system. I have a call into them to see if there is a reset. jjf
    Nichols Hills
    2,465
    Call DirecTV. I'll bet the issue isn't in your dish but on their end. When we had our bus stored for a month or so, this was frequently the case. They magically "reset" it on their end and it comes on. I think you can also do it online if you have your account set up that way. It's a stupid deal, but that fixes it every time for us.
    May 2010
    Nevada, MO
    32
    I had called them before but whatever they did didn't work. I'll try again. jjf
    If the dish is constantly searching it is not receiving a signal. When we have been away from the bus and Direct TV doesn't see activity they shut off the signal to our receiver, but the satellite locks onto the Direct TV site and we get a message on the TV screen.
    Somewhere within the Winegard system is the problem.
    Dec 2009
    Sevierville, TN
    117
    Your bus satellite system is actually two subsystems. A mobile satellite system which I understand is a Winegard dome. The second system is the DirecTV receiver(s). Some brands of mobile satellite systems rely on voltage from their sister subsystem, the satellite receiver. Winegard domes are one of these satellite systems and uses the output voltage of the receiver to power the LNB of the Winegard. If that voltage is not present the Winegard will constantly search without locking onto the satellite. I would check the “satellite in” cable running from the receiver to the satellite system for continuity. This can be done by checking for voltage at the LNB (13 – 18 volts DC). If there is voltage but the Winegard Dome won’t lock onto the satellite then you probably have a bad LNB or tuner board in your Winegard Dome. Unfortunately most Winegard products out of warranty are throw aways. Winegard has a terrible reputation of not providing replacement parts outside of the warranty period. Hope this helps.
    Nov 2007
    285
    What is an"lnb"? Our system has started to malfunction periodically and I think it may be what you are describing. Ours will lock in but not hold it long term. It will hold it about 10 mins. Eric thinks it is related to watching Southpark, but I think there is more to it than that. If someone could tell me what an "LNB" is maybe I will know enough to call the kvh folks. Thanks. Deb
    I can save you both a lot of future grief. Just replace what you have with a TracStar.
    End of issues.
    Or you can drive yourself nuts screwing with a satellite system that doesn't begin to compare to a TracStar and takes the "recreation" out of recreation vehicle. I went down the path you are going with the Winegard and KVH and after 4 years of TracStar bliss I wonder why anyone chooses anything else.
