Results 1 to 5 of 5
Thread: DALLAS to ATHENS, TX
    Mar 2006
    ON THE ROAD IN THE SOUTH
    2,825
    Question DALLAS to ATHENS, TX
    What would the best route to M&G Brake in Athens,TX be from central Dallas.
    Looking at I-20 to SR-19 and in, or SR-175 to SR-19 and in?
    Thanks, JIM
    Dec 2008
    Clermont
    974
    Quote Originally Posted by JIM CHALOUPKA View Post
    Thanks, JIM
    Google maps recommends the following routing:
    5.Take the ramp on the left onto I-30 W1.2 mi
    6.Take exit 47B to merge onto I-45 S toward Houston1.0 mi
    7.Take exit 283B to merge onto US-175 E/S.M. Wright Fwy toward Kaufman Continue to follow US-175 E
    68.4 mi
    8.Turn left to merge onto TX-31 E/TX-7 Loop E/US-175 E toward Jacksonville1.5 mi
    9.Slight right onto the TX-19 N ramp to Canton0.1 mi
    10.Keep right at the fork, follow signs for Downtown and merge onto TX-19 BUS
    Depending on your starting point in Dallas, it should be about 75 miles, give or take.
    Mar 2006
    2,825
    Thanks for all that work Michael, I have the route. What I was looking for was road condition, something from a local or recent traveler or some comment like, stick to I-20 US-175 is not fit for bus travel or..........................
    JIM I see this thread posted a day late??????????????
    Mar 2009
    Harrison
    623
    Jim, you may still be having problems, I noticed my sent message on this thread (#3) of yesterday has dissappeared. Hmmm just thought I would let you know.
    Jul 2009
    Dallas
    240
    Jim,
    I took my bus down to M&G this Spring, used 175. It's a good road, no problems. As a side note I find the M&G System easy to hook up and as far as I can tell it works well. I pull a Jeep Wrangler so if it wasn't for the rear camera probably wouldn't know it was back there. Also I don't know what toad you are going to get done but you might ask them if they have a rebuild available for it. They had one for mine and it saved me a couple hundred bucks. I believe a rebuild is as good as new.
