So what was wrong with the macerator, electrical or mechanical?
With the macerator discharge entering below the graywater by-pass valve wouldn't you then be creating a black water by-pass with no more control than the macerator pump switch or did I miss interpret something you said?
Do you mean when your job is done the grey water will then exit the bus in the right rear at the existing macerator discharge?
I do not have a hose bib at the exit point of my grey water by-pass.
Jim,
On mine, the grey water bypass discharge pipe was threaded PVC, so I just adapted down to a garden house fitting.
My gray water by-pass exits the bay downward as a copper tube, but then it has a No-Hub fitting (a rubber connection) to a PVC elbow to which is attached a copper hose connection.
I am merely rerouting the macerator discharge to go from the macerator outlet to a point on the gray water discharge tube, below the shut off valve and above the floor. To discharge gray water open the valve. To use it for the macerator, close the valve and turn on the macerator pump.
My macerator motor is fine but the pump will not pump. My guess is the impeller is shot. There are kits available so i will rebuild iut and keep it as a spare. With less back pressure to pump the waste the impeller should last much longer. I could have just added a hole in the bottom of the bay and had a hose connection strictly for the macerator but I don't like adding holes.
Jon: I guess you know you made my day because my cheapy model Liberty has plastic pipe. I'm sorry to hear you are having the trouble though. I guess I better be happier with my plastic pipe. Maybe I should find some plastic polish and polish them babies up. Well here's the minor bit of flak you anticipated. You are still our fearless leader though. Metal men hate plastic and I'm no exception. We were building solar water tanks of stainless steel, some areas had corrosive fresh water supplies and required copper tanks. So SS would not be an option for waste water. Lead, lead coated copper cast iron or plastic are the only choices.
Cheers
Harry
Shirley & Harry / 2000 Liberty / 2008 GMC Envoy Denali
Jon, This is probably a dumb question but why did you have to disassemble the piping? On mine I can clean in place, By the way that reaction in that piping could be coming from your water source. Also I use WENOL metal polish, just wipe it on and let dry and polish very easy.Distributor is Reckitt Benckiser a german Co. Tel:+49(0)621-3246-570
I could use 316 Stainless and that would be sure to work but I think given the prices we used to pay for 316 sheet stock when we made drains for the chemical industry it would be cheaper to replace the bus rather than the piping.
I may be polishing plastic with you Harry, but I like the bling. Roger told me to say that.
Gary,
I pulled all the piping apart because I needed access to remove the macerator and in doing so I decided to revise the outlet location from the rear of the bus to a fitting at the waste bay. I did replace the one tube previously because it had perforated from some chemical reaction. The replacement is experiencing the same thing and I don't understand that because we do not use any cleaners (we don't use Drano, or toilet bowl chemicals, or even Comet. We do use dish soap and shampoos but maybe it is something I ate like all them oysters at Wintzels.
Every now and then (at least until Kevin took the wind out of my sails) I have to jab the guys on here about such important things as polishing slack adjusters and copper pipes.
BTW, I use Flitz, or Mothers, or Blue Magic (from Walmart), or any other cheap stuff that will work. When I am desperate I use the stuff in the kitchen that is used to polish the bottoms of Revere wear pots.
Jon, if your trying to zero in on any particular food your eating, I think you might look at all those acidic tomatoes you said you grow and can
Seriously, didn't you say the water on your mountain top retreat was terrible. Maybe there is a connection.
If your macerator was the same vintage as mine, the impeller parts are no longer available, so I had to change out the entire pump. I found a new pump assembly on e-bay that was a direct replacement, no plumbing changes needed.
