Towing Lights
The left stop light quit working on my Toad. An inspection of the plug on the back of the coach revealed that no voltage is being sent to it.
Does the Prevost use a relay setup for toad lights? Is that perhaps the small box at the top of the engine compartment on the left, above the main electrical box? Mine has a switch on it to select the type of turn signal, red/yellow.
-fred
- You may not post replies
- You may not edit your posts
Forum Rules
