Results 11 to 20 of 23
Thread: CruiseAir
  1. #11
    Jasper
    3,775
    Keep in mind a conversion from R-12 to 134a involves a hose change and the cost at Prevost to switch the dash air to 134a was north of 8000.00. This has been beat to death on the forum, so do a search and read all the info before making any decisions.
  2. #12
    Jul 2010
    Lufkin
    401
    Have you checked your voltage?.. we burned up a compressor due to low voltage... the compressor kept trying to kick in and the voltage was too low.... however with your genset running your voltage should be good if all is well with it.. we have had to leave certain RV parks that only show to have 105-107 volts coming in on one of the legs or both and the cruisairs will not run on low voltage.That has just been our experience ! Good luck..
    Diane
    Quote Originally Posted by BillhymerMD View Post
    We also are having trouble with out rear CruisAir. In blows hot air except at infrequent moments when the compressor engages and its cold for a few minutes. We are on our cross country voyage and currently in Southern New Mexico in the El Paso / Las Cruces area. We are hoping someone has a contact for CruisAir repair in the state. AAP does not have anyone for a few hundred miles. Any help is much appreciated. Mike
    Larry & Diane Byrd
    Lufkin Texas.
    1998 Vantare H3-45 D/S SOLD
  3. #13
    Jul 2010
    Peoria, IL
    34
    Voltage appears fine as our other 2 CruisAir are running fine...thanks for the input.
  4. #14
    May 2007
    Port St. Lucie, FL
    1,745
    Usually, if low voltage to the compressor is an issue, you will get a "lo ac" message displayed on your SMX control.
    I believe that if the sensor sees 100 volts or less for a period of 1 minute, it will shut the system down and display the "lo ac" message.
  5. #15
    And if the CA shuts down due to low voltage it has to be manually rebooted by removing all power from the circuit and restoring power.
  6. #16
    May 2007
    Port St. Lucie, FL
    1,745
    Yes. And, keep in mind that the correct voltage needs to be programmed via the touchpad. I had one unit that somehow had the incorrect voltage programmed and had to be reset to the correct value. How this could happen is a mystery to me.
  7. #17
    Jul 2010
    Concord,NC
    66
    Could you be more specific to where the evaporator is located ? Tks!
  8. #18
    Nov 2006
    thomasville,nc
    1,209
    The evaporator is usually just below or near where the cold air discharge is located.
  9. #19
    Sep 2011
    35
    Why don't you just head north/high was 36 here at diamond lake today,and there was a guy water skiing//joe
  10. #20
    Nov 2006
    Wilsonville, OR 97070
    852
    Are we talking Diamond Lake, Oregon?
