Page 6 of 6 FirstFirst ... 456
Results 51 to 58 of 58
Thread: Fuel economy
  1. #51
    Petervs Guest
    Hi Jon,
    I am not an expert on pre DDEC or DDEC 1 systems, but I can not imagine that the fuel supply is controlled directly by the throttle position. The engine would flood out if you opened the throttle too quickly, the metering control has to sense the air pressure in the cylinder or going into the cylinder and respond to that.
    Perhaps someone else will have a definative answer.
    Peter VS
  2. #52
    Peter,
    On mechanical engines (pre DDEC) the throttle position determined how much fuel the injectors supplied. A wide open throttle at low boost (low RPM) resulted in unburned or incompletely burned fuel (black smoke).
    On DDEC I the same condition could temporarily be created. The computer was not as sophisticated as on later versions, and until the turbo spooled up you could roll out the black smoke with excessive throttle.
    Our later versions will only allow fuel quantities that can be almost completely burned.
  3. #53
    Just Plain Jeff Guest
    All the above ignores the PBF factor, which can be deliterious as to fuel economy.
  4. #54
    JPJ, Don't you have some mail to sort?
  5. #55
    Sugar Land, TX
    1,307
    Default Ultra Low Sulfur Diesel
    I know I saw a post just yesterday about the difference between the ULSD and our older diesel fuels, but can't find it.
    So I am posting this website on this post site, HOPE you don't mind.
    http://www.clean-diesel.org/
    Gary S
  6. #56
    lewpopp Guest
    Doesn't the "potentiometer" come in there somewhere?
  7. #57
    Lightbulb Elaborate--For LEW:
    lewpopp;Doesn't the "potentiometer" come in there somewhere?
    Lew, The elaboration of your query.
    Automotive jargon: Throttle position switch. = Electronics jargon: potentiometer.
    Personally I think you new that!
  8. #58
    Nichols Hills
    2,465
    In the older mechanically governed 8V92's there was actually a piston that pushed oil out of a tube with a small hole it it that acted as a buffer between mashing your foot in the throttle and the fuel system going to full fuel. If you wanted to improve your pull from the stop sign, just drill the hole bigger, but be ready to face the fact that the sun was going to be blocked out by the black smoke.
    The Cummins PT fuel system used an aneroid valve that sensed turbo boost pressure and adjusted the fuel flow accordingly. Mack "Maxidyne" engines had a similar feature on their high pressure injection pump.
    I think this is all for naught in the new engines as the sensors and computers keep this all in check with electrons and or 1's and 0's.
  1. NY Fuel
    By truk4u in forum MISCELLANEOUS ITEMS
    Last Post: 06-07-2009, 11:03 AM
  2. 10 reasons I know the economy is bad
    By sawdust_128 in forum On the Lighter Side...
    Last Post: 04-11-2009, 04:51 PM
  3. Oh no, we're out of fuel?
    By Jeffery Raymond in forum Quirks and little known Prevost Information
    Last Post: 04-10-2009, 12:42 AM
  4. Fuel
    Last Post: 12-12-2008, 08:00 AM
  5. Fuel Economy w/ toad?
    By adamdegraff in forum TOADS, TRAILERS & TOYS
    Last Post: 05-28-2008, 01:18 AM
