Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 40 weight oil getting impossible to find
    1,137
    Lloyd, we go to a local lubricants dsitributor for our Delo 100 SAE 40. Its running less than 15 bux a gallon, and has a higher flash point than the Delvac 1600. the info specifically states use in 2 stroke Detroit diesels , where the Delvac does not.
    Number: 235094; MSDS Number: 6938
    Vendors: No vendors are listed for this material. Please click here if you are a supplier and would like information on how to add your listing to this material.
    Printer friendly version Download as PDF Download to Excel (requires Excel and Windows)
    Export data to your CAD/FEA program Add to Folder: My Folder
    Physical Properties Metric English Comments
    API Gravity 24.5 ° 24.5 °
    Viscosity Measurement 98.0 98.0 Viscosity Index; ASTM D2270
    Kinematic Viscosity at 40°C (104°F) 145 cSt 145 cSt ASTM D445
    Kinematic Viscosity at 100°C (212°F) 14.4 cSt 14.4 cSt ASTM D445
    Ash 1.67 % 1.67 % Sulfated Ash wt%
    Chemical Properties Metric English Comments
    Total Base Number 12.0 12.0 ASTM D2896
    Thermal Properties Metric English Comments
    Pour Point -15.0 °C 5.00 °F ASTM D97
    Flash Point 245 °C 473 °F ASTM D92
    Component Elements Properties Metric English Comments
    Phosphorous, P 0.0460 % 0.0460 %
    Zinc, Zn 0.0560 % 0.0560 %
    Some of the values displayed above may have been converted
    Feb 2008
    Lunenburg, NS
    515
    Tuga we pulled the pumps and tested them for water flow and then burped the system. We have a Webasto and the previous owner lived in LA and never used it (the toe kick heater were enough and easier to use). Joe ran enough coolant through the system to finally flush out all the air. That seems to have been the problem all along. The only air bleeder we could find on the schematic or the lines was at the Webasto. We never could find one in the bus.
    Jim thank you for the info.
    Nov 2007
    285
    Quote Originally Posted by lloyd&pamela View Post
    Thanks everyone. I found a place in Indianapolis to get some and we are heading there Sunday. I will have to start going to more Detroit shops, because Napa, Auto Zone, Advanced, and Walmart are not stocking straight 40 anymore, at least not at the stores we visited.
    Lloyd:
    Good evening. I know you two usually stay at one spot longer than we do. Reason I mention that is because our small town local NAPA store has always been able to get me as much Rotella T Straight 40 weight as I need, even though they do not stock it. Gallons usually about $11.89. They don't carry it, but will order it for me and usually have it next day. I know you now have enough on board for your next oil change, but in event you find yourself needing some on one of your "extended stays" somewhere, NAPA might still be viable option.
    Eric Faires
    Huntsville, TN
    Feb 2008
    Lunenburg, NS
    515
    Thank you that is a great idea. Safe travels.
