Charles,
Email your address and I will mail it to you.
Ron
Charles,
Ron
Ron & Suzie Hampton
2001 Marathon H3-45
Ford Edge towinf 4 down
Ron,
There is a check valve on the outlet side of the pump to prevent city water from backing through the pump and into your fresh water tank. If that check valve is working properly, you shouldn't have any city water filling the water filler bowl.
You may already be aware of the check valve, but just wanted to give you a little FYI that I learned during my recent water heater project.
Chuck,
It's in the mail.
Ron
Ron & Suzie Hampton
2001 Marathon H3-45
Ron,
Seal received and installed today. No biggie to install. Found the bushings(bearing) seems a little loose. Hope the seal will do the job. Stay tuned for any further developments.
Thanks again for your generousity.
Chuck
