Results 1 to 4 of 4
Thread: Horn button relay
    lewpopp Guest
    Default Horn button relay
    Horn Both ( air and elec) quit working. Where do I look for the relay or the fuse?
    Jasper
    3,775
    Drivers side top compartment above the steering bay.
    River Ranch, Florida
    382
    Lew, Try adjusting you steering wheel. May be a loose wire in the column.
    Mike
    Nichols Hills
    2,465
    I think it is a loose nut behind the wheel..........
    Lew, I have the complete set of XL wiring schematics (electronically), but since you don't do large pdf files, this will not help. If you can't find it from Tom's description, let me know and I will run it down and tell you where it is.
    And you are sure it is not the horn button rather than the relay or the selector switch that changes it from air to auto horn? I believe there is a fuse for this function as well.
    JW
  1. Refrigerator Relay
    Last Post: 04-26-2010, 11:17 PM
  2. musical horn?
    By Jim_Scoggins in forum MISCELLANEOUS ITEMS
    Last Post: 11-15-2007, 07:07 PM
  3. Air Horn Problem
    Last Post: 02-07-2007, 09:17 AM
  4. Allison Transmission Push Button Shift Selector
    By win42 in forum Engines, transmissions, axles and wheels
    Last Post: 12-19-2006, 12:48 PM
  5. Refrigerator Relay
    By MangoMike in forum Busted Knuckles and Greasy Jeans
    Last Post: 09-13-2006, 10:49 PM
