Originally Posted by
kmuller
Looks like we figuired it out. This morning I pulled the coach right up to the barn, plugged the 50 amp reel in and ....worked great. Unplugged the 50 and tried the 30 amp Marinco...worked great. There appears to be a voltage drop in the 50' of 30 amp extension I was using. Either in the cord itself, or the plug ends (most likely source). The lower voltage was not allowing the transfer switches to pull in hard, they were just sitting there chattering. The transfer switches on the liberty are pretty beefy and evidently very voltage sensitive.
As one of our marine tech's said, the coach doesn't know how long the cord is, only what the voltage is or isn't. This could happen regardless of what cord you are using if the wires were damaged or plug ends not up to snuff. With 5, 10, 15, 20 year old plugs and cords out there, it would be good to check them frequently for voltage drop.
