Results 1 to 4 of 4
Thread: Pro Heat
    Joe Cannarozzi Guest
    Default Pro Heat
    Our bus has E-Spar, its in-op. I believe its a bad fuel pump, $350 and that aint happenen, its 22 year old stuff. So I found a Pro-Heat never used on bus-nuts site for $400. A local charter service place suggested this unit when I was asking about replacing the E-Spar some time back. I know most of you have Webesco.
    How much is a new Webesco (24 volt) not installed?
    Does anyone have a Pro-Heat or have any info in regards to reliability and or value? Im assuming these are probably priced close to Webesco new, 400 seemed very reasonable.
    Mar 2006
    Santa Barbara
    3,177
    Thee is also Hurricane, and Aqua-heat. The Hurrican I had in my Lexa was quite small and very good.
    Jun 2006
    Indian Hills
    1,138
    We had two different coaches with the Hurricane Hydronic heating. At sea level it worked very well. But get much over 5000 ft in elevation, and it becomes irratic. Running flame outs all the time. Country Coach went from using the tried and true Webasto to the Hurricane in 2000, and lived to regret it. they no longer use Hurricane.
    dalej Guest
    Joe, don't know if you have ever looked at this site, this is a FAQs link.
    http://www.hydro-hot.com/product-info-faqs.htm
  1. A/C & Heat
    By GDeen in forum Ah, Nice Coach...
    Last Post: 03-23-2009, 12:16 PM
  2. Engine Heat
    By dalej in forum Busted Knuckles and Greasy Jeans
    Last Post: 01-14-2009, 05:19 PM
  3. Heat Pumps
    By Joe Cannarozzi in forum Quirks and little known Prevost Information
    Last Post: 01-29-2008, 06:12 PM
