I would like to jump in here to give you all a run down on what we have done related to battery technology. On our Triple Slide coaches we have been installing 8 of the traditional gel type batteries and 4 of the Outback Inverter systems, I did this since the Triples Slides do not have Over the Road Air and I wanted enough starting capacity to run multiple Cruise Air systems simultaneously. The Triple Slides do not have Over the Road Air for two reasons, one being the inability to duct the air and the other is the 750-800 lbs of weight that it eliminates which a majority of that is on the front axle. Our Triple Slide units had the 8 batteries divided 4 on the driver side and 4 on the passenger side of the 4 bay (Over the Road Air bay) which basically was a trade off weight wise to the Over The Road Air.
I have been studying the Lithium Ion batteries for a while and did some testing last fall, it is important to note that we are using Lithium Iron Phosphate batteries which utilizes phosphates as the cathode material, this makes the battery very stable since phosphates are not prone to thermal runaway and will not burn. I bring this up because I'm sure there will be a number of you that will Google "Lithium Ion" to the end of the internet and find information completely unrelated to the technology we are using.
I have been able to install 3 of the 24 volt Lithium Ion batteries instead of the 8 gel units we were using in the past, this proved to be virtually equal in capacity and in fact with the elimination of cables, racking, and various other parts the weight of the coach dropped by 1,150 lbs compared to an identical coach with the 8 gel batteries, close to 700 lbs from the front axle alone.
Since these batteries communicate on their own network we are triggering the generator auto start by amp hour usage instead of voltage which means we are utilizing the battery capacity more efficiently.
There is no way to rationalize the additional cost of these batteries by determining if the generator will run less or by how many times you will have to replace batteries over a certain length of time. I can tell you that there is a monitoring system on board that will give you the complete history of the batteries and they do have a cycle life of 2000 cycles. A cycle is the battery running completely dead and charged back up, which should actually be more than 10 years. As a manufacturer and dealer this will allow us to show future purchasers of these coaches that the batteries have "X" amount of cycles left which will ultimately save the purchaser money and eliminate the monumental waste we have related to battery replacement.
This technology is very cutting edge and the information that is available on the control network is amazingly complete in fact we are currently developing software which will allow us to stream that information on our Crestron system so customers can view how may hours of capacity are left at a certain amp draw until the generator will start; this is just a start.
I know that I'm not on here very often, but I will try to look through here occasionally. If there are any questions you have about this or anything else please do not hesitate to contact me directly. Also I would like to thank all of you for your continued support of our industry, with out you we would definitely not be able to continue looking for improvements in technology and quality to move this industry forward.
Frank Konigseder
Vice President/Co-Owner
Liberty Coach, Inc.
