Results 1 to 3 of 3
Thread: Air system tire inflation
Hybrid View
    May 2006
    Diamondhead
    447
    Default Air system tire inflation
    Approx. how many Lbs of air can the air outlet (chuck) in 1st bay deliver to a tire?
    Aug 2006
    Polk City, FL
    205
    Good afternoon,
    The pounds of pressure can never be more than you have in your air system. We usually run the bus with the compressor maintaining around 110 pounds of pressure. Please remember that as the tire is inflated the pressure in the system will go down until it reaches a point where the governor will allow the compressor to kick in again. Also, as the pressure gradient decreases relative to the tire the cfm will also decrease.
    Hope this helps.
    Aug 2009
    507
    Quote Originally Posted by nrhareiner View Post
    Unless you use an air-doubler.
    http://www.dickmantires.com/air_pres..._pressure.html
    These devices trade off CFM for pressure. (NFI).
    David Brady
    '02 Blue Bird Wanderlodge, LXi
    Asheville, NC
  1. Hopkins tire air monitor system $359
    By Danss in forum WANT/NEED PARTS?
    Last Post: 01-30-2009, 07:58 AM
  2. Tire Inflation Question
    By VegasDogMan in forum Engines, transmissions, axles and wheels
    Last Post: 10-12-2008, 04:55 PM
  3. Tire monitor system?
    By Tully in forum Ah, Nice Coach...
    Last Post: 04-09-2008, 11:13 PM
  4. Tire Safety System
    By gmcbuffalo in forum Engines, transmissions, axles and wheels
    Last Post: 05-29-2007, 11:18 PM
  5. Tire Inflation
    By Jon Wehrenberg in forum Busted Knuckles and Greasy Jeans
    Last Post: 03-01-2007, 07:42 PM
