Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Torque multiplier question(s)
    sawdust_128 Guest
    Default Torque multiplier question(s)
    I know everyone talks about the X12 http://times12.com/wrench.htm
    so what's the advantage over something like this one from northern?
    http://www.northerntool.com/webapp/w...5001_200315001
    or over the Mountz products?
    http://www.etorque.com/html/hand_multipliers.htm
    or more like these
    http://www.etorque.com/html/mtmtorquemultiplier.htm
    Another question, if you have one, have you ever used it for anything other than your coach wheels?
    What else did you need to make it functional (e.g., extensions, sockets, reaction feet, etc.)?
    Alexandria
    2,161
    SD,
    I have the X12 and since you're applying about 500lbs of force you need that second arm which is secured by the adjacent lug. Without it I doubt you could make it happen.
    Mike
    More over at Prevoman.com
    http://www.prevoman.com/Pages/Cool%20Toos/x12.html
    May 2008
    Boerne, Texas
    401
    First, from what you have referenced and what I have seen, the multiplication ratio of most of these is usually 3 or 4 to one. Not enough. Especially for overtightened nuts, steel on aluminum, for instance, and where the nuts actually act as centering pilots on the studs so the wheel is centered. The spherical mating face of the nut and the receiving wheel hole are high friction.
    Second, the torque reaction must be taken out somewhere. On the X12 for truck (coach) wheels, it is taken out on the next nut or stud. Even if you use the reaction wrench handle that comes with these other devices, a man usually cannot keep the whole thing from turning (or apply enough torque, usually). You just apply the force to be multiplied with the X12. I have seen large shop impact wrenches (1 inch drives) fail to budge the wheel nuts on my Bluebird, and the mechanic cursed and went and got the X12. ZIP, using the ratchet wrench that comes with it.
    Trust me, sooner or later you will get one, or use a one inch drive wrench and one long (6 foot?) cheater pipe and hope the small enough turn you can get to break the nut loose will be eough, or it will be a long day.
    May 2008
    Boerne, Texas
    401
    I meant the SECOND man cannot hold the reaction wrench handle from turning, it has been mhy experience.
    Ed,
    The X-12 is the big boy equivalent of the examples you have shown. Ken nailed it. If your wheel was installed by some guy with a 1" impact wrench and he just rammed the nuts home it is going to take a lot of force to loosen them and you have to use 1/3 the force to loosen nuts that may have been installed to 1200 to 1500 foot pounds. Good luck on that unless you have a helper and a 4 foot extension.
    I haven't had to use my X-12 on the road, but I have used it at home extensively to torque my wheels. Any time I have to pull the wheels I use the X-12 to apply the torque, something I cannot do with a 1" wrench. I am contemplating getting a torque stick because the X-12 is heavy to use.
    Sep 2009
    Anchorage
    177
    I was just about to order the X-12.
    What is a torque stick? Is it better?
    Nov 2006
    Huntsville
    3,135
    The X12 people also make a universal model that has a flat arm that rests against the adjacent lug instead of fitting over it. This model is designed for people who have multiple applications that they can use the wrench with. I bought one of these universal models when I first got my X12. Because of the high torque that is required to remove the lugs, the universal model would not work correctly on the bus. It slipped when I turned the wrench.
    The model that Mango shows is the one you need. I called the X12 people and told them about the problem I was having, and they sent me the one Mango and Jon have. Great customer service considering the fact that I told him I I had a used unit. Because I have a 1" air wrench, I have only used my X12 to do the final torque on the lugs, but that is the only way I have to accomplish that task.
    Dale & Paulette
    Orren Zook Guest
    Quote Originally Posted by James View Post
    Here's a video that shows how the 'torque stick' works:
    http://www.asedeals.com/video_accutorq_sockets.wmv
    Sep 2009
    Anchorage
    177
    Quote Originally Posted by Orren Zook View Post
    Thanks, looks like the ideal thing to have if you're using an air wrench.
    Dec 2006
    Las Vegas
    181
    Default Pawn Shop
    I am a regular at Pawn shops and see 1" drive 750 Lb torque wrench's for sale in the ~$200 range. I got a super wrench for $175.00 in Reno a couple years ago. The handle is two part and almost 6' long. It still takes a pretty fat boy (like me) to click it at 500 Lb.
    I checked Ebay and nice units can be had for about the same money.
  1. Question
    By dalej in forum MISCELLANEOUS ITEMS
    Last Post: 01-17-2009, 01:42 PM
  2. Old question
    By sawdust_128 in forum OVERNIGHT PARKING
    Last Post: 07-30-2008, 08:37 AM
  3. A Question
    By grantracy in forum Engines, transmissions, axles and wheels
    Last Post: 03-05-2008, 07:56 PM
  4. Oil Pan Drain Plug Torque - Series 60
    Last Post: 11-25-2006, 06:58 PM
