Results 1 to 10 of 35
Thread: Slide vs No-Slide
    Ah yes, the eternal question. Slides or no-slides. The question haunts POG members like a tick on a dog.
    Here's the thing. Slides are great. You quickly increase your living space when open. If they are Prevost slides, you have great support . something goes wrong, you call Prevost 24/7 and they will walk you thru an answer and get you on the road. Heating and cooling are not an issue in my coach no matter the temp outside.
    Just like everything else on a coach, you need to maintain the slides. No big deal.
    Structurally, Prevost over engineers everything so thats not a concern unless I'm hauling goats.
    My Coach is very quiet travelling with no air leaks, rattles, squeak, noise, etc.
    With my kids, dogs, my wife and I there is abundant room to relax with the slides open.
    My last two coaches had slides, so were past that question.
    Apr 2007
    Miami,fl
    309
    We have a two slide coach and it is unlikely we would ever have a non-slide coach. Our slides are after market and were mfg. by HWH who by the way give great support. The only problem we have encountered is a failed switch which we were able to jump( this in over three years of use) I view the slides as a desirable option ( like any other option/sytem) and the attendant maintenance as a small price to pay( so far)
    Granvil Tracy
    2000 Vantare XLV45, S-2
    Pinehurst
    950
    We have had a non-slide Prevost and currently have a 2 slide Prevost. As Roger said, we enjoyed the non-slide and really are enjoying the current bus. When I started looking for a newer bus I wanted bunks for the kids. I really didn't want slides because we typically do a lot of driving (800 miles on Saturday) on our vacations and other than a trip to Disenyworld every year we rarely sit in the same place for more than 3 days. Long story short, I bought this bus for the bunks and not the slides. However, I really like the slides and would have a difficult time going back to a non slide bus. We had a problem with the roof leaking which Prevost fixed as a warranty item. So far (knock on wood) no other real problems. I do expect there to be more issues to deal with given the slides (more moving parts equals more issues or at least more maintenance). I agree with Gary that I would stick to Prevost slides because Prevost did engineer the bus to have slides. I was concerned about being isolated or the bus feeling really small with the slides in. Not the case with our conversion because of the way the converter does the build out in the slides retaining a very large window to the front and rear.
    Granvil,
    What was the two slide Vantare doing at Millennium?
    Default Slide V. Non Slide
    As you may or may not know, one division of our company leases to entertainers and our fleet is made up of Prevost XLII. We have slide and non-slide units. Here is my brief thought on the issue. As many have said, if you are going to be in a location for an extended period of time, it is great to have slides. You obviously get more room, etc. If all you are doing, like many others have said, is running the highways to get to a destination and not be on the coach full time, a slide may not be the best choice for you. It really comes down to personal choice. Keep these things in mind: how many will be on your coach? Is it just you and your spouse? Will you use the coach for entertaining? Are you using it full time? Just a few thoughts.
    Regarding function and maintenance of a slide: I would not purchase a coach that does not have factory slides from Prevost. Personally, I will not run a coach that have third-party slides. Like Jon has mentioned, it is a little nervous thought to have a whole cut in the side of the coach! Who better to do it than a company who has an engineering and design team that knows their product inside and out. I for sure would only go with a coach with Prevost slides!
    Our coaches run 80,000 + miles a year. We have not had any problems, issues or concerns with our slides.
    I hope you find this information beneficial!
    Rob Russell
    www.russellcoach.com
    Rob,
    That seems to me to be a pretty resounding endorsement of Prevost slides! A fleet of XL IIs with slides and no issues, no problems, and no complaints.
    Apr 2007
    Miami,fl
    309
    Loc:
    The two slide Vantare got hungry and decided to eat some dollars..no secrets out there is there? What started out as a little lipstick change has evolved into a minor face lift.
    Granvil Tracy
    3,775
    Hey Gran, I saw your bus in person and it looked like 3 cans of silly puddy went off above your dash! Gee, hope they know were all those wires go.
    I know someone with a great picture you can use as the "before'"
  1. Slide Seal
    By JIM KELLER in forum Prevost Shells and Prevost Car Company
    Last Post: 08-17-2012, 10:02 AM
  2. Slide Mechanisms
    By rockcreek in forum Prevost Shells and Prevost Car Company
    Last Post: 11-03-2009, 12:07 AM
  3. Installing Slide(s)
    By jmoorelewy in forum Busted Knuckles and Greasy Jeans
    Last Post: 08-28-2009, 11:56 AM
  4. To Slide or Not to Slide?
    Last Post: 11-29-2006, 09:27 AM
