I discovered that I had a noisy bearing on 1 of my idler pulleys for the belt that runs the 270 AMP 12 volt alternator. It is a fairly easy job to fix.
1. Loosen the bolts that hold the plate with the pulleys to the backing plate on the engine. (that is the 2 bolts in the slots on the plate.)
2. Use the bolt at the top of the plate to loosen the tension on the belt and remove the belt.
3. The hard part seems to be getting the dust cover off of center of the pulley. I had to use a large dull chisel and come at it from the side and kinda tap / pry it out. I tried several other things and nothing else I tried worked. You may want to remove the dust cover before you loosen the belt. That way the pulley won't move on you while you work.
4. Once the dust cover is off remove the center bolt.
5. With just a little prying from the rear, the pulley came off.
6. Use snap ring pliers and remove the snap ring.
7. I used a large socket and drove the bearing out of the pulley with very little trouble.
8. New Bearing came from Prevost, Part Number 510618, cost $72.05. The bearing is a NACHI part number 30BGS1D53. I could not find that bearing on line or at the local NAPA store.
9. I used a large 1-15/16" socket to drive the bearing back into the pulley.
10. Re-install the snap ring.
11. The pulley went back on the stud on the engine with very little persuasion.
12. Install the bolt, dust cover, and belt.
13. Tighten the top bolt to get tension on the belt, then tighten the 2 bolts that hold the bearing support plate to the backing plate.
NOTE: I need to get a belt tension gauge, will look for 1 today.
14. Test your work.
