Results 1 to 4 of 4
Thread: Air Pressure Regulator
    Default Air Pressure Regulator
    I'm busy chasing down some nuisance aux air leaks and found that my generator air bag pressure regulator is leaking.
    Anything special about replacing it? Is it simply a matter of matching it up at the local hardware store?
    Thanks.....
    Jan 2007
    1,600
    Paul, I purchased mine from a Napa store. The new regulators came with new gages.
    99 Country Coach 45XL
    Jeep Liberty
    Thanks, Jim.
    I'll check them out...
    lonesome george Guest
    Paul,
    I replaced mine about 6 months ago for the same reason. The original regulators (ours had two) had no gauge, I replaced them with regulators that had an integral gauge. Turned out the operating pressure for my bags is less than 20 psi, you might consider using a low pressure regulator maybe 0-30 or 0-60 psi to get it in the middle of the operating range. The gauges look goofy to me, 120 psi gauge with the dial at 18 psi on one side and 12 psi on the other.
  1. Aux Air Pressure?
    Last Post: 11-21-2014, 06:08 PM
  2. Surge Guard 50A Voltage Regulator ?
    By Johnny in forum Electronic Gizmos, Computers and Communications
    Last Post: 09-04-2009, 06:49 PM
  3. Alternator/Regulator failure
    By jack14r in forum Sparky's Corner
    Last Post: 06-23-2009, 12:50 PM
  4. Replace an Air Regulator
    Last Post: 12-17-2006, 02:23 PM
  5. Mystery Regulator
    Last Post: 11-28-2006, 01:29 PM
