Results 1 to 8 of 8
Thread: Coach Fire
    May 2007
    Port St. Lucie, FL
    1,745
    Exclamation Coach Fire
    One of our neighbors here at the Outdoor Resorts in St. Lucie West had their 202 Monaco Signature go up in flames.
    At about 7:00 am a week ago Friday, the owner awakened to what he described as a "fog" in the coach, and went outside to investigate. What he found was the engine compartment ablaze. He did not remember any smoke alarm going off.
    As you can see, the engine compartment suffered the most severe damage, but the inside looks just as bad. No real answer as to what started the fire as the engine was off, yet we all know that certain engine components still retain electric current, which is the suspect cause.
    It is interesting to note that in the middle of the fire, apparently as insulation was burning off some wiring, the engine actually started cranking over! Didn't last long but a real attention getter!
    This guy takes meticulous care of his coach. Always serviced, even the most minor issues taken care of. They are full-timers and this is a serious blow to their lifestyle.
    Apr 2007
    Biloxi, MS (Beautiful Mississippi Gulf Coast)
    97
    Paul: That really looks bad. Who was it or their lot number? Sure could not tell anything about the coach from all the dammage. Glad they were not hurt. Ed
    May 2007
    Port St. Lucie, FL
    1,745
    Ed,
    That coach belongs to Roger and Flo, in the cul-de-sac. No one hurt, but a total loss of the coach.
    FWIW Progressive Insurance was on the scene within a couple of hours of being notified.
    Having experienced a serious engine compartment fire I can say that our coaches have a firewall around the engine compartment that will not be easily breached. Seeing the photos I do not see the same level of protection.
    Our fire was so intense on the passenger side that it literally melted every chassis and house battery, and while the external cannister of the air cleaner was not penetrated, the heat inside it was so great the air cleaner element ignited. Yet despite that we had no smoke odor or soot in the house, the clothes in the rear closet were unaffected, and every single house system worked the three days we remained in it hooked up to Prevost JAX shore power. Even though every house battery was destroyed our converters supplied all the 12V power we required.
    Obviously once a fire gains a footing and spreads beyond the engine compartment all bets are off on our coaches, but having experienced an engine fire I am more confident of our coaches than ever.
    Jan 2007
    1,600
    Is that the harmonic balancer on the engine ? I never realized the motor sat that low in those model coaches
    99 Country Coach 45XL
    Jeep Liberty
    Mar 2006
    Santa Barbara
    3,177
    Default More info
    Can they determine the cause of the fire? It would be nice to know how some of these fires get started. Is there any capacitors or voltage regulators which could cause this. Transformers, ballasts, loose connections at different terminations. Its important to keep an eye on the electrical connections.
    Prevost has one heat fire sensor in the engine compartment. I wonder if Monaco had a sensor.
    May 2007
    Port St. Lucie, FL
    1,745
    The recovery team arrived Tuesday to remove the coach. They used a winch to pull it off the lot, a wrecker to tow it out of the immediate area and ultimately a flat bed to haul it away.
    Not pretty....
    Mar 2006
    Santa Barbara
    3,177
    Hi Paul. How are the owners doing? Is there any new news on the cause of the fire.
  1. Pelican Lake Coach Fire
    By rickdesilva in forum Sparky's Corner
    Last Post: 11-12-2009, 03:10 PM
  2. Bus Fire
    By JIM KELLER in forum MISCELLANEOUS ITEMS
    Last Post: 12-21-2008, 03:56 PM
  3. Fire Detector
    By flyu2there in forum MISCELLANEOUS ITEMS
    Last Post: 03-11-2008, 09:47 AM
  4. Fire Extinguisher Nag
    By Just Plain Jeff in forum MISCELLANEOUS ITEMS
    Last Post: 08-06-2007, 08:52 AM
