Results 1 to 10 of 10
Thread: Oh no, we're out of fuel?
    Jeffery Raymond Guest
    Talking Oh no, we're out of fuel?
    It's legendary that bus owners are afraid they are going to run out of fuel...which incidentally in a big bus is pretty bad news, as it is quite an operation to reprime the system.
    Of course, the easy solution is to keep plenty of fuel on board anyway.
    On most Prevost coaches there is a tiny little connection near the fuel tank, should be inside the bay--and not usually even noted in the Prevost manuals--the idea being, put a bit of fuel in the tank, put some air to the valve and it reprimes the system.
    Nice bit of trivia to pull on another owner if you have the chance.
    Mar 2009
    Harrison
    623
    Default Please
    I have had recent problems with loosing my prime (no remarks please) on my 8V92T over a couple days parked. We repaired the check valve in the Primary Fuel Filter/Water Seperator which was fouled with all kinds of gunk, and to be on the safe side, I now close my fuel shut off valve which is located right below my 24 & 12 volt Battery Disconnect switches in the Right Side eng bay. Would love to know more about this air/prime capability just in case. I watched Jacksonville Prevost mech prime my engine at their facility, and know that I do not want to manually have to EVER do this.
    Dec 2006
    442
    My understanding is that the best solution to running out of fuel is to have a MINI attached as a toad and use it to push the coach so that you could refuel. I forget what topic it was posted under but I know it was discussed on POG
    Wendy and Rick DeSilva
    '08 Marathon H-3
    2017 F350 platinum
    Mahwah, NJ
    Brant Beach, NJ
    Pelican Lake, Fla
    May 2008
    Boerne, Texas
    401
    You may want to reconsider the idea of turning the fuel valve off when finished with the coach. Forgetting to turn it back on before attempting starting just once could conceivably result in air being sucked back into the line (the check valve is for forward flow and would not prevent fuel from being pulled in that direction).
    Clogged fuel filters could do this just as well, as you have discovered. While the fuel pump (at the fuel tank) would supply fuel after the valve is reopened, if there is air in the injectors, that won't help. Some have been lucky and gotten the engine to fire relatively quickly afterwards, other have not, even when the pump prime has not been lost.
    On the base of the fuel filter (where the cartridge screws in) is an allen headed plug. This is on the filter base next to the water pump.
    When that plug is removed that is the priming port. I tell you this not so it will solve your loss of prime problem, but so you know where to pump raw fuel into the engine in case it will not start.
    A garden pump up sprayer with a threaded adapter is all you need. Pump a gallon or so through that port, restore the plug and the engine should fire. I have no clue where the check valve is in your system.
    Huntsville
    3,135
    http://forum.prevostownersgroup.com/...ead.php?t=2632
    This is the post that Rick is referring to. It shows Roger's solution to being out of fuel. I am sure Roger can see more humor in this event today than he did when it was happening.
  1. How much fuel???
    By flyu2there in forum Country Coach
    Last Post: 11-12-2009, 09:55 PM
  2. NY Fuel
    By truk4u in forum MISCELLANEOUS ITEMS
    Last Post: 06-07-2009, 11:03 AM
  3. Fuel
    Last Post: 12-12-2008, 08:00 AM
  4. Fuel Biocide
    By jonnie in forum Engines, transmissions, axles and wheels
    Last Post: 09-17-2007, 05:29 PM
  5. Fuel Leak
    By CAPT MOGUL & Sandy in forum Busted Knuckles and Greasy Jeans
    Last Post: 09-17-2007, 03:18 PM
