Elliot,
What appears to be happening is when your go to the travel or ride position the center solenoid is functioning as it should allowing aux air to flow through the ride height control valves.
When you go to the manual position and attempt to raise the front it fails because one of the top two solenoid valves or valve coils is failing to function. When you attempt to raise the front manually both of the top two solenoid valves come into play. My guess without getting further details from you is that the second one down is functioning correctly because the bus will go down, but the top one is faulty because it will not go up.
Since it appears the third one down is funtioning as intended don't change that one. It appears the second one down is also OK. So swap the top one with one of the bottom two and see if the problem with the front goes away. If it does you know what part has failed. If that does not solve it report back with details and I will go further into the system but right now my guess is with the solenoid valve or valve coil.
