Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Digital Aux Air Pressure Gauge
    3,775
    Ted - Actually the gauge in the steering compartment is pretty close to the digital.
    Jon - Some of the old trucks used to have a pressure gauge in the dash group for brake pressure and I thought that was was good. It wouldn't be too difficult to tap into the brake system and this gauge can read two different pressures by installing a single throw double pole switch. It would be easy to see how much pressure it takes from the aux to move air bags, so I may do a little experimenting while hooked up to shop air.
    Feb 2006
    Bristol, Tn
    1,647
    Jon:
    Jdub needs holding tank pressure.
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
    Re: JDUB's holding tank pressure.......I am not sure pressure gauges go to infinity.
    Truk,
    I had a little tongue in cheek on the gauges and what we could monitor, but I for one would be interested in doing some instrumentation because apart from satisfying a bit of curiosity, gauges on each air bag system (L Rear, R Rear, Front) would provide not only a lot of information, but would also be used to measure system health.
    Jul 2007
    East Texas
    946
    Jon, could you install a Schrader valve on each line you wanted to monitor and then use a system like Doran or Pressure Pro to see where the pressures are?
    Yes. That would work, but I'll bet it would be pricy. With a little wiring a system could be created to monitor a bunch of points using one gauge and some switching, such as a rotary dial switch.
    Feb 2008
    Lunenburg, NS
    515
    Thanks this is just what I need to install. The link is here, http://www.air-zenith.com/products.a...=4&menuid=2436
  1. Digital Cameras needed
    By lloyd&pamela in forum MISCELLANEOUS ITEMS
    Last Post: 12-03-2009, 08:30 AM
  2. Tire pressure gauge
    By jelmore in forum Busted Knuckles and Greasy Jeans
    Last Post: 07-05-2009, 09:43 AM
  3. Digital vs Anolog T.V.
    By JIM KELLER in forum Electronic Gizmos, Computers and Communications
    Last Post: 12-16-2008, 10:14 PM
  4. Digital 101
    By Joe Cannarozzi in forum POG Forum for the Computer Challenged
    Last Post: 10-23-2006, 12:20 AM
