We are travelling in some very warm parts of the country and haven't had less than triple digit temperatures in a couple of weeks.
When I switched off the OTR air conditioning upon arrival at Rancho California, the condenser fan motor failed to shut off. Only way to shut it off was to use the 24V disconnect in the engine bay. I thought that hopefully, the fan motor relay was just hot and kind of "stuck".
Naturally, when we started to depart Rancho en route to Indio, the condenser fan failed to start when I switched the system on.... so no OTR for the trip to Indio
I checked the breaker (CB9) and it was OK so I felt pretty confident that the problem was the relay. After a consultation with Jon, I searched and found a pair of replacement relay's which are labeled R38 and R39 for the evaporator and condenser fan motors.
These relays are made by Prestolite and are model SAS 5401A. Prevost part # 561005.
Replaced the suspect relay and all is well
Photo shows the 2 relays....
