usually I would pass on commenting here - but about a year ago we traded our pride and joy 1994 Liberty straight across to a dealer for a new Pleasureway Van - 26 footer on a mercedes sprinter chassis. Nice ride, new, warranty, and it got twenty miles to the gallon. The problem here is that in my mind both units were about equal value - though I had far more in the Prevost. Both give you a place to eat, sleep, and travel down the highway - but there is a tremendous difference in the experience - the Prevost will take you anywhere a bus that size can go - with all - I repeat - all the comforts of home. The one we bought was purchased as is/where is in about 2006 - it replaced a 1999 Beaver Marquis 40' non-slide coach. This particular Liberty was taken to the Detroit Diesel/Allison shop in Redmond, Oregon where I paid for a prepurchase inspection then based on the result of this inspection which included full electronic analysis and records - I paid for a full service on the engine, transmission, and chassis. The total cost was about $2,000 and I was very pleased as I had a coach I could safely drive anyplace. It needed six new tires (two front tires were new) and a set of chassis batteries and the coach batteries. It needed about three hundred hours of time to replace light bulbs, put in a new water system which had been frozen up in Maryland sitting outside in winter at a shop that was supposed to be fixing it, replace almost every one of the mini-lights in the instruments and controls up front - and run down numerous lousy repairs done by supposedly reputable shops around the country. A new HeadHunter pump, filter system, and several fittings in the water compartment got water going. The Webasto heat system was not operable, opened the valves on both the intake and outlet side, took a look at the control system, and determined something definitely was wrong - but before starting a big tear down - checked the small mini-breaker up on the control box - and it was popped - five minutes after opening the valves, resetting the breaker, and turning it on - we had an operating Webasto system which actually was in good shape and did not even need a new nozzle or filter. By this time I had realized I made the buy of a lifetime on this coach - less than 20,000 miles on a new engine rebuilt by Detroit Diesel and an Allison 5 speed which was perfect. Odometer said about 38,000 miles but it had been replaced around 60,000 when the original died. No idea where the 38,000 came from but service records obtained from CarFax put the coach at about 80,000. Brand new for a bus like this. Actual out of pocket expense for parts and repairs was about $ 1,000 dollars - and that three hundred hours of labor which I did myself. That time would have run at least $ 30,000 in most shops - The tires and batteries were about $ 4,000 to $ 6,000 dollars but that is not repairs - that is just normal upkeep which had been deferred. We drove this bus many happy miles with no problems at all. Prevost provided me with original electrical and air schematics for this actual bus. It cost a phone call.
All in all -my as is/where is bus cost me $ 150,000 which was a bargain - and about $ 10,000 dollars out of pocket to make it usable. When we got it the waste tanks were full, the water tanks empty - but it came with full propane and the propane system fully checked - for those of you not very familiar with a Liberty all-electric coach - I had the opportunity - and could not resist asking to see the propane tanks that were just filled. It was hilarious as compartment after compartment was opened only to find no tank.
This is way too long - but about half of the so-called experts out there cause more problems than they fix. If you have the skills, and the patience, there are many good coaches out there - but they may need a lot of things fixed - these are coaches that are fairly complex but very straight-forward mechanically and electrically if you can get it back to factory configuration.
My advise would be - if you live in my part of the country or near this part of the country - buy a Marathon - we live in Oregon near Eugene - and they will work on a Liberty these days - but they are Marathon experts - if you live near Chicago Liberty is probably the best coach to buy. If you want assurance of a good deal, and in my mind a good deal is one you can drive and use - the factory stores are excellent and you get what you pay for. They usually provide new coach experience for a used coach price. They are not cheap - but my coach would have been a complete disaster for someone who has not done a lot of coach work in the past and did not care how many hours it took to make it right - I enjoyed the project - and am back looking for the next one - just don't tell my wife that yet.
We sold the Sprinter Van and bought a really nice 2007 Corvette Roadster so these days we motel it in luxury - but we still miss that old bus at times.
Chuck W.
POG 15
