Results 1 to 7 of 7
Thread: ABS LIGHT
    Oct 2008
    Tavares
    1,092
    Default ABS LIGHT
    2000 Country Coach......ABS light is on ( and has been for a few ).......
    Is this an immediate concern or can it be dealt with a bit later???
    Brakes seem to be working fine.
    Thanks
    Jamie
    2008 Millennium H3-45
    2013 Chevy Avalanche
    Jamie,
    I wouldn't worry too much about it. Mine lights up every once in a while, mostly when it is humid. After the humidity dries up it goes out. It usually doesn't stay on for very long, maybe 3 minutes.
    How are you enjoying the Country Coach?
    Anaheim
    566
    Jamie,
    The late XL chassis had the rear sender inside the rear end housing, not a great location. I think a lot fail and it is not a cheap fix. My personal opinion is if you are not on snow or ice, it's not a big deal.
    Mine, like the ABS system on other coaches lights when it is damp. It goes off when things dry out.
    There is a switch in the steer bay on my Vintage coach that can be used to flash the codes.
    If it is on all the time it might be worthwhile to flash the codes to see what it is saying is wrong. If it's the sensor in the rear end you may opt to not do anything, but if its just a simple fault it might be worth fixing. I have the books so at OKC if you want to borrow them come and see me.
    3,782
    Jamie,
    It happened to me once with your bus. Flashed the code in the steering bay and it was a rear sensor. The instructions are in the Meritor manual. Reset the ABS and all was good. Don't be concerned if the ABS light doesn't go out after resetting. You have to drive and exceed something like 5 mph before it goes out.
    Dec 2009
    Sevierville, TN
    117
    I too have a ABS fault that has a Fault code of SID#13, FMI#3 and reads "Retarter shorted to 12V" Anyone know what can be done with that?
    Feb 2010
    Polk City
    102
    Default ABS Light
    My ABS light came on in a Monaco (I know I know) I once owned. It was caused by a fire in the inside wheel area. Excess heat can cause the sensor to fail thus causing the ABS feature to fail.
    Yea, I put it out. As an after thought, I probably should have let it burn. At the time I was afraid I would receive a ticket for littering.
    Ron & Suzie Hampton
    2001 Marathon H3-45
    Ford Edge towinf 4 down
  1. Marker Light Lense
    By truk4u in forum WANT/NEED PARTS?
    Last Post: 02-16-2010, 08:04 PM
  2. ABS check warning light
    By sticks in forum MISCELLANEOUS ITEMS
    Last Post: 02-05-2010, 08:07 PM
  3. HI-LO Battery Light
    By tdelorme in forum Ah Houston, I think we have a problem...
    Last Post: 09-12-2008, 09:08 AM
  4. Light Problem
    Last Post: 04-07-2008, 11:50 PM
  5. Light Replacement
    Last Post: 03-25-2008, 01:11 PM
