Results 1 to 3 of 3
Thread: Fuel additives
    ken&ellen Guest
    Exclamation Fuel additives
    Since I am busy changing fuel filters on my gen set and Webasto I guess fuel is on my mind. Since all the diesel here in VA is reduced sulfur should I be using an additive? If so which one? I was in NAPA today and they have every conceivable brand as well as formulas. Suggestions or recommendations. Ken
    This response if offered without the complexity of actually having knowledge about the subject.
    If you run frequently and are keeping the fuel fresh I would not be concerned about additives. If you sit for extended periods, especially in hot weather, I would be concerned about the growth of algae, but beyond additives to stabilize the fuel due to inactivity I would not feel the need to add anything.
    What does DD suggest?
    Orren Zook Guest
    As long as you buy your fuel at a reputable truck stop you shouldn't need any kind of additive during the warmer months, in extremely cold conditons an anti-gel might be needed, but only if the coach was to set outside for an (not running) extended period of time in sub zero weather. I also try not to fuel when a tanker is unloading to underground tanks as that will stir up any water/condensation that has settled to the bottom of the tank.
  1. NY Fuel
    By truk4u in forum MISCELLANEOUS ITEMS
    Last Post: 06-07-2009, 11:03 AM
  2. Oh no, we're out of fuel?
    By Jeffery Raymond in forum Quirks and little known Prevost Information
    Last Post: 04-10-2009, 12:42 AM
  3. Fuel
    Last Post: 12-12-2008, 08:00 AM
  4. Fuel Additives
    By Sid Tuls in forum Engines, transmissions, axles and wheels
    Last Post: 10-20-2008, 09:19 PM
  5. Winter Fuel blends and additives
    By Joe Cannarozzi in forum Target Practice
    Last Post: 12-14-2007, 09:04 PM
