Results 1 to 5 of 5
Thread: Doran Tire Monitor
    dreamchasers Guest
    Default Doran Tire Monitor
    For Your Information.
    My neighbor is the owner of a 1997 Royale. He recently installed Doran's new tire monitor (360). On a recent weekend trip, the tire monitor alarmed on an inside dual that reached 90 psi. He stopped and rechecked the tire pressure with a gauge to be sure of the pressure. He air up the tire to normal pressure and reinstalled the monitor, thinking that the tire was low when he installed the monitor.
    After an overnight stay, the inside dual had leaked down to 50 psi. He was able to have the tire repaired and go safely on his trip with no tire related mishaps. To think of what could have happened with a tire pressure of 50 psi, at road speeds, blow our for sure!
    I am a Doran user and recommend the system.
    Hector
    Joe Cannarozzi Guest
    What have they changed on it from the old?
    dreamchasers Guest
    Joe,
    The new Doran Tire Monitoring system has a different display and more program features. In my conversation with the Doran's home office rep, the one feature that was added was the ability to trigger an external alarm. That is the one feature I do wish I had on my existing system. I do have to keep the display panel in sight to see any alarms. With a remote alarm, an alarm lamp could be triggered, alerting you to look at the monitor.
    My morning check of tire air pressures is as simple as scanning through the tire positions on the monitor.
    I am a user of the original Doran monitor and I am very happy with the system. I have used the system on two different RVs.
    Checkout the link below to read of the Doran 360 unit.
    http://www.doranmfg.com/rvtirepressuremonitors.htm
    Hector
    Apr 2006
    Battle Ground, WA
    851
    Could be wrong but seems to me the Doran and Pressure Pro use the same valve-stem senders. We installed the Pressure Pro system on Tom's bus and liked it a lot. It has an initial oral warning that beeps when tire pressures exceed or go lower than 12.5% of the set value, a continuous beep occurs when a 25% deviation is reached.
    Jasper
    3,775
    Brian has spoiled me! I now push buttons to check my tires and I do it often.
  1. Computer Monitor Print Size
    By JIM CHALOUPKA in forum Sparky's Corner
    Last Post: 02-15-2009, 01:46 PM
  2. Hopkins tire air monitor system $359
    By Danss in forum WANT/NEED PARTS?
    Last Post: 01-30-2009, 07:58 AM
  3. Tire Monitor systems
    By 0533 in forum Electronic Gizmos, Computers and Communications
    Last Post: 09-04-2008, 12:53 AM
  4. Tire monitor system?
    By Tully in forum Ah, Nice Coach...
    Last Post: 04-09-2008, 11:13 PM
