Results 1 to 8 of 8
Thread: OTA TV Antenna Upgrade Advice
    Apr 2008
    Knoxville, TN
    104
    Default OTA TV Antenna Upgrade Advice
    My 2003 came with a Braund Concord motorized TV antenna with the controls in the passenger's armrest area. While I have been able to coax it up and down, it is very unreliable, and there have been times I did not think it would come down. If you press the buttons on the controller just right, it responds, usually takes dozens of presses to get it down. When it is down, it still looks bad. One time we arrived at our destination to find the antenna in the up position (it was down when we left). I think it is time for a replacement.
    We do use the OTA antenna to feed local stations into our DirecTV DVR, so giving it up is not an option.
    The Braund antennas are still available through Barker Mfg, but the whole thing seems dated. I have used omnidirectional antennas in the past on boats, with reasonable results, and I like the idea of a fixed, low-profile antenna (Winegard RS2000), but I read the reception is not as good. Winegard also makes a motorized antenna (MA1000W) similar to the Concord.
    Has anyone gone down either of these roads? Results? Other ideas?
    Thanks!
    John & Janene Browder
    Knoxville, TN
    2008 Marathon H3-3S
    Aug 2007
    Scottsdale
    158
    We went with a fixed antenna, I believe it is a Roadstar. We have 2-boosters attached, and we get reasonable reception. We sometimes use it while driving (not an option with the big ugly motorized antenna!), and are able to pick-up local channels generally within 25 miles of the source. We also get digital HD with this antenna on the HD over the air stations.
    Steve & Rhonda Bennett
    Dana Point, CA
    92 Marathon XL40
    2012 Jeep Rubicon Unlimited
    John,
    I have been wanting to change to an omni-directional TV antenna also for the same reasons you mentioned.
    Sounds like Steve has nailed it with his Roadstar + boosters.
    We had similar concerns with our motorized antenna as it became less reliable positioning it up and down. We ultimately replaced it with a fixed, omni-directional OTA antenna.
    Don't recall the manufacturer as it was installed by Liberty Coach in Florida.
    We're very happy with the digital HD reception we get.
    And best of all.....no moving parts!!
    Apr 2008
    Knoxville, TN
    104
    Sounds great: simplify! I am off to CW to get a Roadstar. I will attempt to use the old Concord base as a platform to mount the new antenna. Thanks for the input.
    Knoxville, TN
    2008 Marathon H3-3S
    3,775
    John,
    I'm doing the same thing using a mounting plate already installed for an older antenna. I'm going for the RS1500 because of the way it mounts instead of the RS2000 with the 3 legged mount. Best price on the net for the 1500 is 64.99 and 94.45 for the 2000. Much cheaper than CW.
