I went out this morning to perform my monthly run of everything on the bus, and the refrigerator would not run. I wasn't sure of the procedure for removing it, but I now have done it, so I will share that with others who have a CC.
I am not 100% sure it is the start relay, but it is the most common component to go bad; and I checked the amperage draw on the compressor, and it appears to be normal. Removed the old relay, and it was blazing hot, so I assume it is burned inside. Tapped on the old relay a little and put it back on, and the compressor started.
My refrigerator is a Whirlpool, Model ED20TQ. The start relay is a part # WHP2262185. You don't need the WHP when searching for the part. After significant searching, I ordered the relay from www.ApplianceZone.com for $29.90 including shipping. Another source is www.AppliancePartsPros.com. The relay is also available from most local appliance parts houses at a higher price.
Note: You can probably replace the relay without disconnecting the electric power cord and ice maker water line. I disconnected everything, because I wanted to be able to turn the unit completely around and clean the fan and coils while I had it out.
Below are the steps I took in removing the unit and replacing the start relay. This should apply to most of the CC buses that are about the same vintage as mine. This would be easier with two people, but since Paulette was at work today, I was the only one around, so I did it by myself.
1. Remove the dinette table by removing the 4 screws that hold the decorative cover then remove the 4 bolts. Be prepared to suppor the weight of the table. It is heavy.
2. Rmove the front cover on bottom of refrigerator unit.
3. Open the little cabinet above unit and remove 2 screws that hold the top trim above the unit.
4. Remove carpet and bottom panel from pantry just to left of refrigerator. This will allow you to unplug the unit. Takes less than 5 minutes.
5. Place 1/4" paneling or thick cardboard in front of the unit so you roll unit out without scratching the floor.
6. Remove the front panel from bottom of the unit. It just snaps on. Use small pry bar to raise unit a little while you pull on both sides of unit at the same time. The pry bar raises the unit a little from where the wheels have sunken and made an impression. I placed the pry bar under the metal lip of the front of the unit, stepped on it and pulled the unit forward.
7. Disconnect ice maker line at rear. Hold large brass nut with a wrench while turning the plastic connector. Be prepared to catch the water that runs out the line.
8. Remove cover from relay on left side of compressor. Place a large flat blade screwdriver in the lip on top of the cover and turn to left while gently pulling on the cover.
9. Remove relay by inserting a screwdriver between it and the compressor and gently pry it off.
10. Replace relay. Check operation of refrigerator, and make sure you connect water line and check for leaks before pushing unit back in the wall.
