Could someone have put diesel into the fresh water fill spout? Would probably be evidence/stain in that area if that did happen.
I've never seen a diesel fuel nozzle with a hose adapter. On my coach there is no way to "accidently" get fuel into the water. You not only need a hose connection, but you have to open a valve manually and then press a switch to open the electric fill valve.
As an alternative my bus has an expandible plug at the top that can be removed to add chlorox or even to fill from a hose, but a person needs to get into the bay, open the access door to the inside of the bay, actually know that plug is there, and to remove it which is a bit of a pain.
If fuel is in the system My guess is that step one has to be a full system drain. Second refill and flush with some soap or solvent that will emulsify the fuel so it can be carried away. Then that needs to be flushed with many rinses. But I wouldn't waste my time doing that until I knew the secret to how it got there in the first place.
On Marathons, in the curb-side water bay there is a fresh water gravity fill. It could conceivably receive fuel, but as you've said, it seems a real long shot. I think my fill there is like plastic PVC, and I would think there would be evidence that diesel fuel had been introduced there.
The original post didn't seem to indicate whether there is a LOT of fuel in the water, or not.
I will assume he has this issue.
If it plastic I would throw it out or sell it as a waste tank
If it is stainless I would search for info for a possible cleaning solution.
I would be looking for the prankster, just cannot happen.
John
This is crazy to us as well! We just purchased this machine and after a supposedly thorough exam of all systems including the water system which included over 2 weeks of work and constant reassurance that "everything was in good shape now"we were sent on our merry way. Being completely novice and anxious to get going as well we would not in our wildest thinking imagined that they would send us off with contaminated water! When we noticed an awful smell, the owner of the company said, " well you should never drink water from a motor home tank and that smell is just because it has sat for a long time and needs to be flushed out." As we drove home the smell was overwhelming in the coach and of course we couldn't use the water for anything. We drained the tank and kept a jar for testing so we don't yet know the level of contamination, but there is an oily skim on the water and it is cloudy and the smell is very strong.
We wondered if anybody had any idea of what to do next or of an enzyme or anything that would help flush out the oil? Weird, huh?
Diesel smell is almost impossible to make disappear. Just ask any of us that have had a diesel bath from fuel puking from our tanks during refueling.
If I had the problem I would experiment with almost all products that will emulsify diesel fuel and break it down so it mixes with water. As soon as I found one that would make the smell go away from a container like an old milk jug then I would use that product to fill and flush the water system. I still would want to know how it got in the system. Until I learned that I would not be spending a lot of time trying to clean the system. I would want to be sure that someone hasn't maliciously rigged up a way to cross contaminate the systems.
Never heard of anything so strange. We have had funky water in our tank and system and usually a chlorine sanitizing treatment makes it go away. Are you sure it is not water with an odor? Are you sure the anode in the hot water tank is not creating the odor? Is it diesel fuel for sure?
The simple answer is the coach didn't do it.
Both liquids got into the tank.
Could be introduced into the tank seperately (prankster/vandal/idiot) or they could have been introduced simultaneously (i.e., contmainated water supply)
Just some questions:
Where and how was the fresh water last filled and who did it?
Also, do you have the service logs for the coach? Is there any indication that any tanks were pulled for any reason?
I ask, because I agree with everyone on here that it would seem impossible for this contamination to occur on-board. However, it could be that contaminated water was used to fill the coach. Or, possibly that the tanks were contaminated and reinstalled into the coach.
Is it possible that a hose used to flush/syphon diesel tanks was accidentally used to fill your coach?
Also, just curious as to why you are just finding this out now?
Wow! Thanks for all your replies. To Joe, there really is no rest of the story,,,except that we feel like fools for letting them get us out of there without this being fixed. We did ask if there was water in the tank, we didn't ask if it was potable....we just assumed. We bought this old coach and we asked the dealer to do a thorough check of all systems and fix anything that needed attention. We were specific about air system, water system etc. Several thousand dollars later we were told it was ready to roll. We had a quick 2 hour instruction period with one of the men and then spent the night in the unit in anticipation of leaving the next morning at 6am. That night we realized the water was not right and mentioned it first thing in the morning.
{The dealer was to escort us to the state border}. That is when he replied that it had set a long time and needed to be flushed and that nobody should drink water from the tank.
Yesterday we called the dealer again and again he said it was just residue from work they did on the generator and spilled fuel and that all we needed to do was steam down the generator and flush the tank 2 or 3 times.
We are taking a sample of water for testing today. We will await that result before talking anymore with the dealer.
We truly are novices and feel totally stupid about this so we want to be sure that we are not accusing a dealer of bad service wrongly.
By the way, the unit is a Prevost 1989 XL, Country Coach, 190,000 miles. Do they all smell like diesel at that age?
Thanks for all the replies. Will get back with the water test results.
Does this "machine" have a manufacturer? A model? A Brand? It is very difficult to help if we know nothing about it. Is it a Prevost conversion? I have never seen a Prevost conversion with an external gravity fill on the water system. More info please.
Pete & EJ Petree
Sealy, Texas
