Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Storage Pics
    Feb 2009
    Austin, TX
    963
    Default Storage Pics
    Storage unit came out very nice. 1550 sf with plenty of room to work on the bus. Have been adding work table, tools, etc. since I took the pics. Spent most of the day in there yesterday working on a couple of small items and continuing to learn systems.
    Joe Cannarozzi Guest
    50 amp service that's good.
    Now you can accumulate lots more crap
    tool box, compressor, bench, welder etc. etc. table saw radial arm saw lots of room.
    First you get the bus then you talk her into tool-time, that's how it goes. You are following a well traveled path.
    Jul 2007
    East Texas
    946
    Very nice, Gordon. Is there any way to circulate air through your part of the building? It was 95 degrees up here Saturday so I know you guys must have been hot as well. How the heck did you spend most of the day in there with no AC ?
    Be on the lookout for an orphan 50amp cord (or make one) that you can keep in your storage building. It's nice to pull in, jump out and hook up without getting the bus's power cord out. Also makes leaving a snap.
    Mar 2006
    ON THE ROAD IN THE SOUTH
    2,825
    Thumbs up
    Looks real nice Gordon, now the real fun begins!
    I don't know if this needs to be a consideration in TX, but on occasion in the spring the bus and the interior of the building are cold soaked. (Cold being a relative term). The outdoor temperatures will rise faster than the inside temperatures such as on a warm humid day which follows a cold period.
    When that happens the bus, especially heavy items such as the wheels and the engine block, and sometimes the skin at the frame trusses has condensation all over it. Moving air or venting the storage building cures this problem. Dampness is the enemy.
    Feb 2009
    Austin, TX
    963
    Ted and Jon,
    I have placed a large shop fan on the floor in the rear portion of the unit. Obviously, that truly only helps when the door is open since there is no ventilation in the building. I have already spoken with the landlord's broker about installing some vents. He is finishing out the other 3 doors similarly with the goal of attracting more high end storage. Apparently a helicopter is coming into one of the units. Ventilation would certainly help attract tenants.
    Good idea on the cord Ted. Would be nice just to keep one laying off to the side for bus barn only. It was plenty warm in there so I was doing some sweating. Not too bad though. Even with the SMX settings at 85, I am burning some electricity keeping the coach from getting hot. Its all good though.
    My gearhead son was in there poking around while I was working. Should have known what he was up to - he and his brothers gave me a nice lighted work table and rolling tool cart for Father's Day.
    Thanks Jim and Joe. Already repaired a leaking steer stemco and preparing to install smartire system. Needed lots of tools to do all this! MM's cool bus tools page has set me back a few bucks also.
    Apr 2006
    Lake Forest
    2,486
    Looking good Gordon! Makes me want to move where my storage options are more plentiful!
    Mar 2006
    Santa Barbara
    3,177
    Hi Gordon. Maybe the owner might consider some roof gravity fans to pull some heat out along with some low louvers on the doors. If you have access to a telephone line, you might consider a monitered Smoke/Heat and Security Alarm system.
    Mar 2006
    2,825
    Lightbulb
    Gordon, here's the tool you need if your doing all that wheel and tire work.
    http://www.toolbarn.com/product/makita/TW1000/
    I just love how Jim spends other people's money.
    Gordon, if you are a gearhead and want to work on the bus yourself being a ble to remove and remount your wheels is one of the things you will have to do. In the absence of a good air supply and at least 1/2 inch air hose for a 1" air impact wrench you will need an alternative. But.....if your wheels are installed by the typical tire shop employee the 738 foot pounds of torque will not get the job done. Some of the shops that mount wheels drive the lug nuts on with excessive force.
    For the price you may actually be able to buy a 1" air impact wrench and an air compressor with a 60 or 80 gallon tank. For the same price you could buy an X-12. http://times12.com/wrench.htm
  1. Few Trip Pics
    By GDeen in forum MISCELLANEOUS ITEMS
    Last Post: 08-10-2009, 01:15 PM
  2. Ms. Pics
    By Danss in forum RALLIES AND GET-TOGETHERS
    Last Post: 05-17-2009, 09:24 PM
  3. Farm POG '07 pics
    By bill&jody in forum RALLIES AND GET-TOGETHERS
    Last Post: 11-13-2007, 08:36 AM
  4. Trouble uploading pics?
    By jello_jeep in forum MISCELLANEOUS ITEMS
    Last Post: 09-19-2007, 11:00 PM
  5. Large format pog pics
    By jello_jeep in forum RALLIES AND GET-TOGETHERS
    Last Post: 05-03-2007, 07:35 AM
