Results 1 to 8 of 8
Thread: Replacing three belts, Question
    Jun 2009
    Gig Harbor, WA
    340
    Question Replacing three belts, Question
    Little help please. I'm going to replace the three belts that run the AC compressor and the fan pump. A friend of mine told me Gates makes a one piece belt that has the 3 "V's" on it. Is this true, and if so does anyone know the part number, where to buy, etc.
    Thanks All
    Lightbulb
    Elliott, the number I have as posted by Jim Keller is:
    3/A74 Power Band, #90923074.
    Sep 2008
    836
    Jim, before changing belts, please check my post of 4/21/09. My post got walked on and I don't think it was seen. Search for FAN CLUTCH. This is very important! I don't want the same thing to happen to you.
    Pete & EJ Petree
    Sealy, Texas
    May 2008
    Boerne, Texas
    401
    Quote Originally Posted by Pete View Post
    Can't find it, please repeat that post.
    Sep 2008
    836
    Ken, if the belts are too long they will allow the fan assembly to strike the radiator, and the results are not pretty. The fins from the clutch assembly (the round aluminum part) came off and went into the radiator in about 4 or 5 places. I tried to copy the earlier post I made on this subject, but was not successful. You can go to the search function and enter fan clutch, then scroll down to the post. Sorry I can't be more specific on the procedure.
    Pete & EJ Petree
    Sealy, Texas
    May 2008
    345
    Default rocks?
    I asked somebody at Marathon about this. He said that the 3 separate belts were better. His reasoning: if a rock or some debris gets in, it can escape. My reason: The three belts probably break easier than one, big massive belt. When my AC compressor locked up, the three belts all snapped. I viewed this as a good thing. They were a piece of cake to change, and the engine, main pulleys, etc were all fine. I don't see any reason to switch to one big belt, though at the beginning I thought maybe I should. Glad I didn't.
    ~Adam
    Default Here It Is Ken
    Adam your tour is finished right? Where is the bus now?
  1. Belts
    By dsaylrn in forum WANT/NEED PARTS?
    Last Post: 06-15-2010, 01:31 PM
  2. Throwing fan belts
    By ajducote in forum Engines, transmissions, axles and wheels
    Last Post: 05-02-2009, 10:28 PM
  3. Fan Belts
    By Orren Zook in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 02-19-2009, 02:00 PM
  4. Belts
    By adamdegraff in forum Engines, transmissions, axles and wheels
    Last Post: 08-08-2008, 08:33 PM
  5. Seat Belts
    By 0533 in forum MISCELLANEOUS ITEMS
    Last Post: 02-24-2008, 04:22 PM
