Results 11 to 20 of 26
Thread: Chicago - McCormick Convention Center
  1. #11
    tomklau Guest
    Quote Originally Posted by aggies09 View Post
    Jen and I are looking for an RV parking area for about three days in July so dry camping is not really an option for us. Joe, can you or anyone else recommend a park that would have decent access to the train into the city? Help appreciated.
    We've stayed at the KOA in Marengo...Train about 15 mins away and an hour's train ride in. They have a FEW spaces to accomodate a 45 footer, it's tight though.
  2. #12
    jasperjr Guest
    Default Chicago parking
    Tony,
    What days will you be in Chicago? My wife and I will be traveling in and out, but if we are in, you could stay at our house (full hookup) easy access to the Fox River Grove train station (1 hr train ride)
    Just an option for you.
  3. #13
    I believe that we are planning on being in the area for 3/4 nights beginning July 18th. Obviously, it would be more convenient to be closer in, but as I have found out through investigation and this post, that is not an option in Chicago. I sincerely appreciate your offer. Let me know if these dates would be something that may work for you and I can open that possibility up as an option as I plan.
    Thanks.
    Tony and Jenny Conder
    Abilene, Texas
    2008 Marathon D/S XLII
    2017 RAM 1500 4x4
  4. #14
    Joe Cannarozzi Guest
    We currently have some visitors and in attempt to make their stay more enjoyable I called around to see what the charge would be to have their holding tank pumped out so the do not have to drag over to the local flying-J.
    100 gal 195 bucks. Is that a bunch of crap or what.
  5. #15
    May 2007
    Port St. Lucie, FL
    1,745
    So, Joe, you're sayin' it's $1.95/gallon ???
    That's some EXPENSIVE crap!!
  6. #16
    Feb 2009
    Austin, TX
    963
    Quote Originally Posted by phorner View Post
    And people run my industry down for selling crap that has been buried and subject to a perfect mix of heat and pressure for a few million years for a about the same price.
  7. #17
    Is it time to revive the thread we discussed that antiquated system Wenabago used to use that injected the holding tank through a spray tip into the exhaust and burned it.
    If there were something out there like that now that could be installed for reasonable cost I would be on it like flies on crap. (I think it is now safe to define Sawdust as a bad influence)
    Better yet it would be hooked up to the gen exhaust too.
  8. #18
    sawdust_128 Guest
    Joe: that's a crappy thing to do!!
  9. #19
    So instead of covering the countryside with a liquid waste, Winnebago opted instead to convert it to dust and then apply it to the countryside.
    If you could recover it would it be known as instant crap? Just add water and mix?
    Why not just pump it up onto a flat surface on the roof, like an oversized baking tin, and let solar energy evaporate the moisture. Then we can bag the remains and sell it as fertilizer.
    This group is definitely going to Hell.
  10. #20
    May 2007
    Port St. Lucie, FL
    1,745
    I think you guys are on to something here..... after all, that waste is more than 99% water.
    So, if all ya got do is somehow vaporize that water..... the remaining crap should be easy to deal with.
  1. ALBUQUERQUE FMCA CONVENTION 3/22-3/25
    By garyde in forum RALLIES AND GET-TOGETHERS
    Last Post: 03-27-2010, 08:19 PM
  2. RV Park Tampa close to downtown convention center??
    By rmboies in forum TIPS ON TRAVEL
    Last Post: 10-21-2009, 08:54 PM
  3. Campground/Parking near the LA Convention Center
    By lloyd&pamela in forum MISCELLANEOUS ITEMS
    Last Post: 07-03-2008, 12:25 PM
  4. Fmca Pomona Convention
    Last Post: 03-01-2008, 08:58 PM
