I may have missed this on an earlier thread somewhere, so at the risk of being redundant.......customers are showing up with this air pressure booster. It's small, affordable, fast, and it works. Check it out at www.dickmantires.com
or try this one... www.dickmantires.com
Yep...thats what I meant
Is this what I might want? My bus "Aux" system goes to #120 with the engine or even with the 12vdc aux pump, but does not seem to have the CFM to do much (probably due to tank size in Drive lower compartment). I am considering just buying a small 120v ac that will go to 120+ that will deliver more CFM and have the added versatility of being AC and not having to do the tires with the engine running. What say thee?
I carry my Hitachi:
http://www.amazon.com/Hitachi-EC12-2.../dp/B0000225DO
I like it because I can grab it and go with it in the toad. The only thing that I have found is that you will want it running when you start to pump up your coach tires. Let it treat the tire like it is part of the resevoir system. Other wise, you will need to monkey with the shut-off switch which then limits the versatility of carrying this compressor.
Also. since I am going to carry it, I am considering plumbing it in to the aux air system on quick connects so I can eliminate use of the aquairium pump that is curently installed.
rahangman - I'm not selling these........just sharing info, but our customers are very happy with them. Probably an option worth looking into.
I bought one of the Porter Cable compressors that goes to 150 psi a couple years ago, and it works great. Keep it in my tool bay. I bought it off eBay for $125.
