Results 1 to 9 of 9
Thread: General Question
    May 2008
    Boerne, Texas
    401
    Default General Question
    I'm curious about whether anyone has electrical, water, and sewer connections on both sides of the coach. Is/was this standard? If so, does anyone routinely use both? Thanks.
    May 2007
    Port St. Lucie, FL
    1,745
    Ken,
    Our Liberty has electric, water and sewer connections on both sides of the coach. There is a selector switch on the dash to toggle which dump valve to open with the dump switch.
    I have never used the passenger side connections, as I have never had to. Also, I'm not certain that the fresh water auto-fill will work from the passenger side.
    I have used the macerator outlet and it worked fine.
    Nov 2006
    thomasville,nc
    1,209
    Everything on a Liberty will work from both sides.
    Everybody else just wishes they had hookups on both sides.
    About once a decade you get into a wierd situation where it would really be nice. Its a nice feature, I can hook up on both sides if you count the macerator as a dump. I doubt if I would order a coach with the feature.
    May 2008
    Boerne, Texas
    401
    Thanks for the responses. Since I had seen where a Prevost had to turn around to hook up (can't remember the converter), I have been wondering how common my set-up is or isn't. On our coach, we have dumps on both sides, PLUS the macerator. I am in the process now of replacing a 3" short turn 90 degree elbow on the right side that cracked. We have macerator outlets on both sides as well.
    Default both sides
    use the dump function on both sides all the time. I am very thankful to have access from both sides. Very convenient. Especially in the bus barn.
    Tony and Jenny Conder
    Abilene, Texas
    2008 Marathon D/S XLII
    2017 RAM 1500 4x4
    Mar 2006
    Santa Barbara
    3,177
    The dump outlet on both sides has saved me in several situations. I have not used the water hook up on the starboard, nor the macerator as it shorts the fuse.
    Feb 2006
    Bristol, Tn
    1,647
    Default Double Dumps are a plus
    Having owned a Liberty and switching to a CC (that I like) I must confess that is one of the features I miss most is having dumps on both sides. I had my dump set up on the Liberty at home to work on the passenger side while the CC dumps from the drivers side.
    Having to pay the Son N Law for new plumbing at the house to accomodate. Takes 3 to 4 months leadtime. Probably take another 3 months to complete.
    I have been using Macerator to pump tank contents to other side thru a garden hose, but what I think most folks don't realize is that when using a Macerator it is necessary to run quite a bit of clean water into the tank so as to clean out the hose prior to disconnecting. Yes I have two tanks and the gray water empties last, but on Libertys with one tank the black water just keeps on coming.
    For some reason I feel that this should be under a topic heading of "JDUB".
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
    Sep 2008
    836
    My coach has dumps on both sides as well as a macerator on the curb side.
    Although I do not have electric and water connections on the curb side, I have auto reels on the street side with rather long hose and cord that I can connect for curb side hook-ups.
    Curb side connections come in real handy when you want to have a set up with another coach whereby the patio awnings face each other.
    My last coach, a 1985 American also had dumps on both sides, so it must be fairly common to have this feature. (not just Liberty coaches have this feature)
    Pete & EJ Petree
    Sealy, Texas
  1. OKC Rally parking and general info
    By ajducote in forum RALLIES AND GET-TOGETHERS
    Last Post: 09-22-2009, 11:28 PM
  2. General questions I need help on...
    By Tully in forum Ah Houston, I think we have a problem...
    Last Post: 10-07-2008, 10:34 PM
  3. General Information and-a little more
    By Joe Cannarozzi in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 10-10-2007, 08:46 AM
  4. General Admission Charge, say what??
    By rmboies in forum MISCELLANEOUS ITEMS
    Last Post: 06-15-2007, 09:12 AM
  5. General mechanical questions
    By Joe Cannarozzi in forum Busted Knuckles and Greasy Jeans
    Last Post: 06-26-2006, 01:50 PM
