Page 1 of 2 12 LastLast
Results 1 to 10 of 45
Thread: Guest Automatic 5/10 Amp Charger
Hybrid View
    Nov 2007
    926
    Default Guest Automatic 5/10 Amp Charger
    I am replacing my current charger (non automatic) with a new Guest fully automatic one.
    Like everything else I get involved with i thought the install would be a no brainer (I an sure it is for the rest of you) but now I am second guessing the install.
    I have 4 brand new chassis batteries and for the sake of a few $$'s I do not want to fry them because I made an install mistake.
    Here is what is stalling me out. The old charger has 2 leads that are connected to a negative battery post (different battery) and the other connected to a positive post on another battery in the bank of 4.
    The new Guest comes with 4 leads, 2 POS. and 2 NEG. leads.
    Question: What batteries do I connect these leads to, does it matter, Should I connect them to separate NEG/POS terminals on any 4 batteries or to both NEG/POS terminals on any to batteries. Check out the diagram from Guest for 24V installs. It seems different than what I had expected.
    See Link: http://www.marinco.com/product/10-am...rgepro-charger
    This should be very easy but I am reluctant to make the connections without a second opinion.
    I am also having difficulty uploading images to the forum today as well, maybe I should not be doing important stuff.
    Nov 2007
    926
    Default Diagram
    Image diagram
    We have 4 chassis batteries, this diagram shows the 4 leads 2 POS and 2 NEG connected to 2 batteries 1 NEG and 1 POS connected to 2 batteries. How would this application work for 4 batteries, can I just connect the 4 leads to 1 POS on 1 Battery, 1 NEG on another battery??? repeat the same for the other 2 leads or do I need to attach the pairs POS?NEG to 2 separate batteries??
    I hope I am not confusing anyone.
    Alexandria
    2,161
    Hi Bruce,
    I have the same charger.
    Here's a diagram I worked hard at to show the hook up.
    The two center wires from the charger just wire nut together, don't bother attaching to batteries.
    Mike
    Nov 2006
    Sugar Land, TX
    1,307
    Bruce, MangoMikes diagram is exactly what I used to connect my Guest Charger.
    It has worked flawlessly, since I got the wiring issue all sorted out. You'll be glad you have this installed in your system.
    Be sure the Guest Charger is plugged into a hot plug that runs off of either shore power or Gen set, not just when you turn on a timer. I had to replace my existing 60 minute timer with an on/off switch for the system to function properly, but it has worked great since then.
    Gary S.
    Feb 2009
    Austin, TX
    963
    Warning, stupid newbie question......
    What is the purpose of a "guest charger?" Just what it implies - charging other things like your car?
    Nov 2006
    Sugar Land, TX
    1,307
    Quote Originally Posted by GDeen View Post
    Warning, stupid newbie question...... What is the purpose of a "guest charger?" Just what it implies - charging other things like your car?
    Gordon there are No Stupid Questions, or believe me I would have taken the prize for asking them several times over.
    The Guest Charger keeps the (4) Chassis Batteries charged properly when it is parked. If your plugged into shore power at a park, or running the gen set in an overnight situation dry camping, the chassis batteries are being maintained properly.
    Jon, did I answer that correctly?
    Gary S.
    Jeff Bayley Guest
    The purpose of a chassis battery charger like this is for when you park in South Beach and block an entire lane of traffic on a Friday night and are too smashed to move the bus when you get back from bar hoping. You've left the flashers on, you go to be with the flashers on and when you get up in the morning the chassis batteries need to be topped off in order to start the coach.
    Worked great for me and not so much as a single knock on the door from a cop asking me what the hell I was doing there. Maybe he thought I was waiting for Triple A but I was starring at my eyelids.
    Nov 2007
    926
    Thanks Mike.
    They all have inline fuses, should I disconnect the fuse when I wire tie the inner ones together? My guess is get rid of the inline fuse. I will leave the one to the main POS that I connect to the batteries.
    Again thanks, I am somewhat surprised that Guest does not offer this diagram on its website for this unit. The manual did not offer this option either. Where did you find the diagram?
    PS> Gary I do have a timer that will be removed, the A/C power outlet (both Shore/Gen) can be turned on at the dash, I will keep it on at all times to allow it to work when needed. Question: I guess it might come on while running down the road while on the genset as the 270 alternator turns off when the gen side is on while running along, no demand from the house side on Marathon single alternator buses. Interesting solution, could this offset the need for a second alternator??? Jon will know the answer, bet he is out having pizza and Mussels somewhere
    PS> Gordon: Even if you turn off the chassis battery 12/24 volt shutoff there are wires from the chassis batteries that go directly to the DDEC, most owners leave the 12/24 on so they can have access to air for leveling?? and all else chassis related. If the coach sits without running for long periods the battery will run down unless you have a charger. The Auto Charger is the best solution (I had a manual timer version)
    Bruce
    Jul 2007
    East Texas
    946
    Gordon, "Guest" is the name of the company that makes the unit Bruce and others have installed.
    Feb 2009
    Austin, TX
    963
    Quote Originally Posted by tdelorme View Post
    I rest my case....thanks Ted.
  1. Which Guest Charger?
    By LarryB in forum Sparky's Corner
    Last Post: 07-11-2009, 09:27 PM
  2. Changing Standard Transmission to Automatic..
    By Journeyone144 in forum Engines, transmissions, axles and wheels
    Last Post: 07-21-2008, 03:56 PM
  3. Guest marine battery charger
    By Danss in forum Sparky's Corner
    Last Post: 11-26-2007, 10:28 PM
  4. Member / Guest
    Last Post: 02-17-2007, 04:40 PM
  5. Two-Second Guest Room
    By Ben in forum TOADS, TRAILERS & TOYS
    Last Post: 07-12-2006, 03:08 AM
