Somewhere there is a thread with info for that Gloss grey enamel that the engine compartment is painted with. I need that but before I can paint there are some issues.
I have some copper air lines attached with metal clips and the hardware is not coming out. Electrolysis.
I am going to have to grind out the screws and then decide if I will replace with the same to keep the factory look or use something all plastic.
These 3 are across the ceiling and go to the regulator for the belt tension valve. There is another going to the temp sensor for the radiator shutters.
